There is something I don't understand at the very beginning of your LOG:
May-20 11:33:48 AM PLCBUS Debug Rcvd Ack: (138) M4 Off Data1:0 Data2:0 Tx:False AckReq:True Ack:True IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False
May-20 11:33:48 AM PLCBUS Debug Sent: (138) M4 Off Data1:0 Data2:0 Tx:True AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:True PlcBusOK:True
May-20 11:33:47 AM PLCBUS Device Device [138-M4] status set to [Off]
1) You set M4 to OFF
2) The plugin sends a PlcBus M4-OFF command with AckReq=True
This is a first problem here. If M4 is really a PlcBus scene device...the plugin should not ask for an ACK request, as PLCBUS modules never send ACK responses for a secondary (scene) address.
3) The plugin gets an ACK response back !!!!
This is a second problem. As already written, PLCBUS modules never send ACK responses for a scene address.... this means you have a PLCBUS module somewhere with the M4 address set as primary address...
--> It's not possible to have a PlcBus scene address, set as a primary address of any module. M4 must be a primary address or a scene address, but it cannot be both. Same with HomeSeer devices ... you can only have one M4 device. You should not create M4 as both appliance/lamp and Scene.
