Anyone know why this thread was deleted? I was searching for an issue I'm having and it looks like the thread contained some info that might help. Any way to get it back?
Why was this thread deleted?
Originally posted by rmasonjr View PostAnyone know why this thread was deleted? I was searching for an issue I'm having and it looks like the thread contained some info that might help. Any way to get it back?
**ITMPORANT** This message board is for user-to-user support. If you require direct HomeSeer support, please review the options on our main website support page.
(and BTW, I did not misspell "Important". It was posted that way.
Here is a cached first page.
http://webcache.googleusercontent.co...&ct=clnk&gl=us
The other three pages are in the wind.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Originally posted by RJS View PostPerhaps it was deleted because of this announcement on the home page of the message board:
I suspect something mildly derogatory was posted, Rupp took offense, and "threw the baby out with the bath water". Shame since there might have been helpful information in there.
I have since found the solution to the VBNC DataSetExtension issue I was having.HS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
The way to do it is to close the thread with a final post explaining why it was closed - then it becomes a "teachable moment". If someone in the thread violated the TOS or Site Guidelines, the single post should be deleted and the author warned.
There is nothing that will cause anarchy or member abandonment faster than heavy handed moderation.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
^^^^ I agree - delete the offending post, not the whole thread. When my search found that thread, someone had the same issue I was having and now no one will benefit from it.HS4Pro on a Raspberry Pi4
Originally posted by rmasonjr View Post^^^^ I agree - delete the offending post, not the whole thread. When my search found that thread, someone had the same issue I was having and now no one will benefit from it.
Originally posted by RJS View PostBut some of us remember the potential offending posts contained in that thread. They can't take away our memories.
Sent from my Xoom using Tapatalk 4HS4Pro on a Raspberry Pi4
I had to look up "threw the baby out with the bath water" as I never heard that expression before.
There is a wiki for everything these days. (not knowing if it is correct though).
Throw out the baby with the bath water is an idiomatic expression and a concept used to suggest an avoidable error in which something good is eliminated when trying to get rid of something bad, or in other words, rejecting the essential along with the inessential.
A slightly different explanation suggests that this flexible catchphrase has to do with discarding the essential while retaining the superfluous because of excessive zeal. In other words, the idiom is applicable not only when throwing out the baby with the bath water, but also when someone might throw out the baby and keep the bath water.- Pete
Originally posted by Pete View PostI had to look up "threw the baby out with the bath water" as I never heard that expression before.
There is a wiki for everything these days. (not knowing if it is correct though).Real courage is not securing your Wi-Fi network.
Thank you Greg.
Yup I could see that happening back in 18th Century.- Pete
Wow. You've been into home automation for a long time._______________________________________________
HS3 : HSpro (3.0.0.460) on Win2012 (vm on ESXi)
Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, Links
