Attached, modified Weather Display scripts for use with HS3
Usage :
1. create Virtual devices (see names in .txt file(s)
2. Unzip txt files into Scripts folder
3. Edit the txt files and replace the device ID
4. create one event that run the script(s) every minute
I'm going to write detailled documentation
OS : Win7 Ultimate 32 bits french
Country Code 32
Hardware :
Aeon Labs zstick, Insteon Hub, RFXCOM Lan, Current Cost Envi R, Davis Vantage Pro II, Boltek Storm detector
Software :
HS3 Pro 3.0.0.54
Weather Display 10.37R build 78
NextStorm 1.8
Plugins :
HSTouch server 3.0.0.11, android client 1.0.0.44
Zwave 3.0.0.60 : 2 Siegenia CO2 Sensors, 12 Fibaro Wall Plug, 4 Fibaro Smoke sensors, 2 Everspring Flood sensors, 1 Everspring ST814 Temp Humidity sensor, 3 Aeon Labs repeters
Current Cost 3.0.0.9 (disabled)
Insteon 3.0.3.13 : 15 On/off plugs, 3 Dimmer Plugs, 2 Open/close sensors, 2 Motion sensors
BLLAN 2.0.9.0
RFXCOM 30.0.0.5 : 6 Oregon Scientific temperature/humidity sensors
HSPI_CCOST3P 1.0.0.3
Scripts : Reading of Weather Display datas (self modified for HS3 from HS2 version)
Usage :
Country Code 32
Hardware :
Software :
HS3 Pro 3.0.0.54
NextStorm 1.8
Plugins :
BLLAN 2.0.9.0
