Operations with Device
    Hi all,
    I have just installed HS3 and being a newbie, would like some help for the following:
    I have a device that brings back the value of a gaz value (ex :254362). This value increases according to the gaz consumption every minute or hours or days depending of the usage (shower / heating system).
    I would like to have , through the use of a counter or a script, the real consumption between two dates (or minutes).
    Is it possible to do this with the new "event" system or should it be a script ?
    If so, I am not a programmer so I would appreciate some help with the script....
    Thanks a lot in advance
    Regards
    Any help ?
      You could achieve this with an event and script command, but I think it would be easier to implement and maintain later using a small script. Remember that global variables are removed on reboot, so you'll need some other way of persistently keeping the 'previous' value for your calculations.
      I'd suggest an INI file but if you don't mind the 'clutter' you could use a virtual device in HS and write the old value there after you perform your calculations.
      Shout if you need further help.
      Author of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
        Operations with device
        Thanks a lot for your answer.
        I am really a newbie so would appreciate a script model to make what you recommended ?
        Not sure how to make the addition.....
        Could you indicate the different steps to perform ?
        Thanks a lot
        Regards
          Sorry for the delay, I missed your response. Try something like this:
          PHP Code:
          Public Sub Main(ByVal parms As String)
          Dim parm() As String
                  parm
          parms.Split("|")
                  If
          parm.Count <> 2 Then
                      hs
          .WriteLog("Error""Usage: Send two integers separated by '|'.  Device ref of counter, Device ref of virtual usage device (e.g. Main(""100|101"")")
                      Exit
          Sub
                  End
          If
          Dim GasCounterDevice As Integer CInt(parm(0))
          Dim VirtualUsageDevice As Integer CInt(parm(1))
          Dim OldValue As Integer CInt(hs.GetINISetting("data""PreviousValue"0"GASDATA.INI"))
          Dim CurrentValue As Integer hs.DeviceValue(GasCounterDevice)
          Dim Usage As Integer CurrentValue OldValue
                  hs
          .WriteLog("Gas Usage""The gas usage since I last checked is " Usage.ToString())
          hs.SetDeviceValueByRef(VirtualUsageDeviceUsageTrue)
          hs.SaveINISetting("data""PreviousValue"CurrentValue.ToString"GASDATA.INI")
          End Sub
          Save tihs to a script "Gas.vb" and put the file in your \scripts folder. Create a new virtual device in HomeSeer, note it's device reference ID (in the "Advanced" tab of the device). Note the device reference ID of your Gaz counter too.
          Create an event to run the script every 5 minutes and pass the script two parameters to the Main method, separated by '|' e.g. Main("320|150") - Counter first, virtual device second.
          It will moan about the INI file not being there the first time, but after that all should be good.
            operation with device
            Thanks a LOT for your help !!
            I will test this
            Regards
              I followed the process from Berrygaz and got errors.
              See pictures
              Any Help ?
                Sorry, replace
                PHP Code:
                If parm.Count <> 2 Then
                with
                PHP Code:
                If parm.Length <> 2 Then
                  operations with device
                  Super ! It works perfectly.
                  Now I have a question: How can the result of the calculation be reported in the device list .....or through a graph ?
                  Hope this is possible
                    Well the result is reported in your virtual device which is updated every time the script runs. You can look at BDGraph or Jon00's VirtualGraphing scripts to graph the virtual device over time.
                      Analysis
                      PHP Code:
                              parm
                      parms.Split("|")
                              If
                                  hs
                                  Exit
                      Sub
                              End
                      If
                              hs
                      End Sub
                      Hello,
                      I would like to have a second script to check if the gaz counter is not blocked (breakdown or something else..) .
                      Can I use the same script as the one above (will it create conflict in the INI file or any values) ? or should I create a different script with other values and then test every X minutes if the consumption is not equal to Zero ?
                      Thanks in advance
