My Asterisk PBX crashed and I moved everything to a web based hosting company. I am trying to add the lines into the plugin. Everytime I try I get the following error in the web browser:
Server Error in '/' Application.<hr color="silver" size="1" width="100%">
Runtime Error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
<table bgcolor="#ffffcc" width="100%"> <tbody><tr> <td> <code>
<!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="Off"/> </system.web> </configuration></pre></code> </td> </tr> </tbody></table>
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
<!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/> </system.web> </configuration></pre></code></td></tr></tbody></table>
I don't have much else to go on - there is nothing showing in the HS2 log.
Runtime Error
