I don't see the download. Try my 4.83.2.4
Instant Messenging Connector for Live Messenger and Google Talk (Jabber)
This is a sticky topic.
Hi
My IM connector has fixed itself - sort of. The connector works but I now get more than one response for every command I send. E.g. if I send "helo" from the only connected MSN client I get the following back in the IM window from HS:
xxxxXXXXX says
helo
Home Control says
I don't understand. Use HELP for help
I sometimes get one response back, sometimes many but not the same amount of responses for each command I send. Something is not happy! A reboot fixes the issue for a few minutes but then the problem comes back. The HS log (shown below) shows multiple messages too so I think that the IM Connector is seeing the IM message multiple times, not just seeing once and marking as read:
IM Connector user: xxx XXXX says helo
dasvag
IM doesn't connecting to msn
Hi suddenly I have a problem. Since few days ago IM does not connecting to msn. It writes connecting........ Into interface when I make reload config the msn *client status is offline.
At the open the log writes:
11/12/2011 7:32:45 PM* IM Debug* IM Connector : Debug Mode activated. Waiting 0 secs...
11/12/2011 7:32:45 PM* IM Debug* Loaded MSN User*dasvag@yahoo.gr*- Access Level ADMIN
11/12/2011 7:32:45 PM* IM Debug* MSN settings loaded - User:*homekap@hotmail.com
11/12/2011 7:32:45 PM* IM Debug* IM Connector : Found MSN IO device ^2 - Name= MSN - Location= IM Network
11/12/2011 7:32:45 PM* IM Debug* IM Connector : MsnClient connecting to MSN server...
11/12/2011 7:32:46 PM* IM Debug* IM Connector : MsnClient Connected to MSN server
11/12/2011 7:32:46 PM* IM Debug* MsnClient Connection Closed event received
11/12/2011 7:36:11 PM* IM Debug* IM Connector : Unexpected error occured while trying to disconnect previous MSN network object:An established connection was aborted by the software in your host machine
Please tell me what can I do because I have a problem and I haven't any help.
I have installed the plugin version 4.87.2.5 but i cannot seem to connect to my jabber server (ejabberd)
21-2-2014 17:39:21 IM Debug IM Connector : JabberClient Disconnected from server jabber.server.mydomain.something
21-2-2014 17:39:21 IM Debug JabberClient Error: De handshake is mislukt als gevolg van een onverwachte pakketgrootte.
The server has no issue with pidgin client of notification from Nagios (PerlXMPP)
xxxxxxx@xxxxxxx.com - Access Level ADMIN
25/12/2014 07:48:27 ~!~IM Debug~!~Loaded MSN User xxxxxxx@xxxxxxx.com - Access Level ADMIN
25/12/2014 07:48:27 ~!~IM Debug~!~MSN settings loaded - User: xxxxxxxx@live.co.uk
25/12/2014 07:48:27 ~!~IM Debug~!~IM Connector : Found MSN IO device ]2 - Name= MSN - Location= IM Network
25/12/2014 07:48:27 ~!~IM Debug~!~IM Connector : MsnClient connecting to MSN server...
25/12/2014 07:48:28 ~!~IM Debug~!~MsnClient Connecting Error: MSNPSharp.ConnectivityException: SocketMessageProcessor failed to connect to the specified endpoint. See the inner exception for more information. ---> System.Net.Sockets.SocketException: No connection could be made because the taget machine actively refused it 157.56.122.81:1863 at Org.Mentalis.Network.ProxySocket.ProxySocket.EndConnect(IAsy ncResult asyncResult) at MSNPSharp.Core
