Evaluating Plugin
    Evaluating Plugin
    I have this script within vitamind c:\windows\system32\csript.exe /b //nologo c:\client\vitamindd\garagedoor.vbs. It works since vitamind camera application was on the same server as of HS.
    I moved it to a new server and I would like to use the script connector. I configured it as the instructions. I replaced the "Run the command" with the following "c:/program files\homeseer HS2\hsscript.exe c:\client\vitamindd\garagedoor.vbs. When I run it I get the error "the command was not found. Please check that the path is correct and try again" do you know what I'm doing wrong?
    Aldo
    I found an example in the VItaminD post. "wodin" made a great and detailed example.
    Interesting that the vb script need to be in the script hs directory otherwise it would not work.
