Originally posted by mfisher
View Post
HSTouch Android Client 1.0.0.83
Awesome avatar Steve! Who would have thought that a physicist from the early 1900's would become (somewhat) famous because of a comedy show.Best regards,
-Mark-
Originally posted by rjh View PostSteve,
Tried to email you but your email is not working, your domain does not exist.
I have had problems trying to re-create this. If you want to help, load "logcat" (its in the play store), on your screen. Then when HSTouch exists, run it and see if you can find a log entry showing an exception from HSTouch. Email me the log entry.
Are you using the standard project, or your own project? If your own, do you have a different background graphic for each screen?
P.S. Which of the "logcat" do you want me to install? I have started to install one called LogCat Reader on my froyo tablets. Will that one work OK for this?Steve
(System configuration is in my profile)
Originally posted by spknapp View PostIn another thread, Mark mentions that he also has a Velocity Micro Cruz T301 tablet like I have (see post http://board.homeseer.com/showpost.p...7&postcount=10). While we're waiting results from my logcat, can you use his T301 and see if it does as mine does? Mine is just a plain factory load on the T301 and a standard apk install of the HSTouch client and either left at the main menu screen or the weather screen.
I tested this at work, which is not on VPN or anything in this case to my home.
Startup was super quick, and loading the devices was equally as fast.
Big two thumbs up on this so far, I will keep testing and let you know if I do have any major issues. I did note that loading the Weather page does take some time at startup ~ 15 seconds which is a bit long (from click of button to displaying values) so maybe this is something that should be stored as a hs variable and updated each time a client connects (automatically) then hstouch could just grab the values from the server and not have the delay.
Originally posted by rjh View PostPosted an update to the Android client, it has some fixes for memory issues, see if it helps. I can say for sure that if you changed screens it leaked memory and for sure this one does not do that as I checked it with the Android memory analyzer.Steve
Rich,
Does this "Screens are now freed from memory when they are closed" mean that each screen will have to reload - like when you first go to them? If so, will they have the same lag? Finally, if not, did you finally change to using the Binary method of reading in the HSTouch configuration?
--DanTasker, to a person who does Homeautomation...is like walking up to a Crack Treatment facility with a truck full of 3lb bags of crack. Then for each person that walks in and out smack them in the face with an open bag.
This version still force closes if using a project file written for a resolution that is not native for the device you are using it on and use the "Scale to Screens to Fit" option. The app opens fine at first, must faster BTW, and you can navigate to one screen. After that, moving to another screen is when the app FC's.
Example: Screens are made for 800x480. On devices that have a larger screen like 1024x600, 1980x1080, etc, the project will FC the app if you have the app auto scale the project.
Weather Screens take the same amount of time as before - no change in speed - Using WeatherXML.Transitioning to HS3Pro .298 - WinXPEmbedded
Originally posted by Dafunktyfunk View PostThis version still force closes if using a project file written for a resolution that is not native for the device you are using it on and use the "Scale to Screens to Fit" option. The app opens fine at first, must faster BTW, and you can navigate to one screen. After that, moving to another screen is when the app FC's.
Sliders seem to be working properly .
However, still getting images and stuff going missing if I switch between screens after a while (my project has 8 screens, treating buttons as tabs, after the 5th screen change, various parts go missing)
