Originally posted by jon00
View Post
Jon00 Remote Computer Control & Network Monitor (HS2, HS3 & HS4)
Originally posted by jon00 View PostSo has the error gone?
Apr-06 12:41:15 AM Error 3 Running script C:\Program Files (x86)\HomeSeer HS3\scripts\Jon00RCCNM_MonitorHS3.vben :Object reference not set to an instance of an object.-{0x3E}Does entry point Network exist in script? at A.c17b105f989efe61e5979e67bec1ef734.cffd66cb0782c50126727e3f a75582d7a()
Thinking it might be a bug in HS3, I deleted the event and created it again. Still the same error.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
I deleted the event again and created a new one with a different name, still the same error every minute. It is now finding devices that enter or leave the network.
Apr-06 12:50:15 AM Error 3 Running script C:\Program Files (x86)\HomeSeer HS3\scripts\Jon00RCCNM_MonitorHS3.vben :Object reference not set to an instance of an object.-{0x3E}Does entry point Network exist in script? at A.c17b105f989efe61e5979e67bec1ef734.cffd66cb0782c50126727e3f a75582d7a()
Apr-06 12:50:08 AM Z-Wave Device: 1st Floor Michelles Office MS Temperature Set to 69.4 (F)
Apr-06 12:50:08 AM Z-Wave Primary: Z-Wave Wake-Up Notification Received for Node 25
Apr-06 12:50:06 AM Jon00_RCCNM Info - Unspecified device disappeared from Network (IP: 192.168.2.154 MAC: C8-6F-1D-46-65-DD)
Apr-06 12:50:05 AM Event Running script in background: C:/Program Files (x86)/HomeSeer HS3/scripts/Jon00RCCNM_MonitorHS3.vbenHS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
That makes no sense to me.
The error: Does entry point Network exist in script? relates to a call to a sub or function called Network. The script does not even contain a sub/function with that name.
Have you deleted the other event which runs the same script?
Other than that, it looks like it is working.
Is there anywhere else the entry I errantly entered in sub or function could have been stored?HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
I would change the new event to a manually triggered one and than wait. If the error occurs then you need to take a look elsewhere in your events.
If nothing happens, run the new event manually and see if the error appears.
Your entry:
means that it is operating correctly.
My bad! In all of the fiddling with the events, somehow I errantly changed the script in in the Network Monitoring Event to the script for Intrusion. All is well now. Do I need to check the box "only allow a single instance" on this event?HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Jon,
Have you had a look at my issue relating to the WOL variable not showing up and not working?
Its happening on the two HS2 boxes. Both INI files look OK to me. I did reconfigure the application from scratch on the two boxes with a new INI file. I can do a WOL from each box using the Nirsoft WOL waker upper.
I posted it here:
http://board.homeseer.com/showpost.p...&postcount=911- Pete
Well I thought starting from scratch would have fixed it.
That said I did what you mentioned and it worked!
Thank-you Jon!
4/7/2014 9:07:07 AM Event Event Trigger "JonWOLTest"
4/7/2014 9:07:07 AM Event Running script and waiting: WOLtest.vb
4/7/2014 9:07:07 AM Test WolPortNo=74/7/2014 9:10:10 AM Event Event Trigger "DE Touchscreens OFF"
4/7/2014 9:10:10 AM Event Running script and waiting: Jon00RCCNM.vben("main","11+12||standby")
4/7/2014 9:11:52 AM Event Event Trigger "DE Touchscreens ON"
4/7/2014 9:11:52 AM Event Running script and waiting: Jon00RCCNM.vben("main","11+12||wol")- Pete
Thank you Jon.
Yup I had been using notepad to edit the INI file. (IE MAC address changes)
I never did a copy and paste though to a new INI file.- Pete
Originally posted by jon00 View PostI would recommend that you do. That said, there is a bug in HS3 in that it does not work correctly!
If you run in to problems, let me know and I'll tell you how to get around the issue.
Could you tell me what kind of "problems" the "only allow a single instance" on this event might cause? For now it is still selected on both events.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
