Is there a speaker selector available for HS3? I'm just looking for one set of speakers to play under certain conditions and to have the signal sent to a different set of speakers under other conditions. I know the AB8SS is real popular but it's overkill for my needs and also isn't available.
Speaker selector for HS3?
Not quite. I have a Russound system with all zones in use. I want my back yard speakers to not carry the signal from the amp but be diverted to a different set of speakers when certain conditions are met. And I'd like to do it without getting a second Russound amp. So I'm just looking for some contraption which will send the signal from the amp to either speakers A or B. There's plenty of this kind of thing at RadioShack but it's all manually operated. I'm looking for something which HS3 can control.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
So you are looking for an A/B speaker switcher that is controllable via the serial port? If so check out http://www.controlanything.com/ They have many relays that are controllable via serial, USb, etc.
Jesus!
That controlanything stuff is a little out of my budget! Unless, of course, it also controls the French maid it comes with. Does come with a maid.... right?
I think my quest continues.
Originally posted by mrhappy View Post4PDT relay on a power supply plugged into an appliance module? On can be B and off can be A.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Originally posted by S-F View PostWhile $150 is more reasonable than $850 I still think it's a tad rich for me. Also it's a bit overkill. 16 in and 2 out. I really only need 1 in and 2 out. Thanks though!Last edited by mrhappy; January 20, 2015, 10:22 AM.
How about something like this: http://www.ebay.com/itm/NILES-SAS-1-...-/221653472229
Lots of used ones on eBay.
Cheers
AlHS 4.2.8.0: 2134 Devices 1252 Events
Originally posted by sparkman View Post
That one is 2 inputs to 1 output. Otherwise looks good! Can it operate in the reverse? 1 in and 2 out? The ebay one is missing the power supply and I'm not sure where one could be obtained......Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
