CLEAR AS MUD, EH!?!?!
Remote Desktop - Let go my Audio!
Originally posted by Bill BrowerCLEAR AS MUD, EH!?!?!
I thought thats where it should be, but when I click it a DOS screen flashes up then nothing, still connected and HS computer sitting at login screen.sigpic
Originally posted by Bill BrowerDo a search on your harddrive of the HS computer for TSCON. What directory is it in?
TSCON.EXE-0193565B.PF is in /windows/prefetch That file was last modified or created today when I last tried to diconect.sigpic
scentioli
Originally posted by scentioliat the command prompt of the HS Machine type qwinsta
Look for the Session ID
If the SessionId = 0
%windir%\System32\tscon.exe 0 /dest:console
If the SessionId = 1
%windir%\System32\tscon.exe 1 /dest:console
consol HomeSeer 0 active rdpwd
rdp-tcp 65536 listen
If I do it on the remote computer I get this,
rdp-tcp#16 HomeSeer 0 active rdpwd
rdp-tcp 65536 listen rdpwd
consol 2 conn wdcon
I look forwrd to your translation of what that lot means.
Thanks,sigpic
scentioli
Originally posted by GogsTyping in qwinsta on the local computer I get the following,
consol 2 conn wdcon
scentioli
Originally posted by GogsThat was a typo, it says "console"
%windir%\system32\tscon.exe 0 /dest:console /v
and see if your getting
C:\Documents and Settings\steve>%windir%\system32\tscon.exe 0 /dest:console /v
Connecting sessionID 0 to sessionname console
Could not connect sessionID 0 to sessionname console, Error code 7045
Error [7045]:The requested session access is denied.
scentioli
and see if your getting.....................
The problem was a space, I did not have a space between the 0 and /dest:console!
many thanks for all the help from everyone.sigpic
Here is an updated version of this "fix". This one is Windows 8 compatible and will auto-disconnect the correct session for you. Be sure to run it as an administrator (you can create a shortcut to it and check the box that says run as administrator).
Code:@echo off for /f "tokens=4 delims= " %%G in ('tasklist /FI "IMAGENAME eq tasklist.exe" /NH') do SET RDP_SESSION=%%G tscon %RDP_SESSION% /dest:console
