Concord 4 plugin Events - ONLY
    Ok so I had events setup and forgot how I had them...
    If you have a concord 4 alarm please share some events you dont mind sharing. ONLY say what it is, what it does, screen shot...
    so I will start..
    2 events.. that email on status...
    1. arm alarm either armed away or stay - send email alarm set to armed
    2. alarm disabled - send email disarmed
    using concord sensor to trigger z-wave lights
    Real basic, but using a concord wireless door sense to trigger the z-wave lighting.
      Auto-Lock Deadbolt
      Not sure if this is the best way to accomplish this, but it seems to work for me. If you close the shed door and fogret to lock it, it will fire off the z-wave deabolt after the concord door sensor returns to normal for a minute.
        Thanks guys.. this is what im talking about... so I am doing it a different way.. not using the Security like both of you are doing unless security is in the name and you maybe doing it the way I am but if not.... .my way works... but different. when I get back from vaca im going to be redoing it ALL.. basement is almost done and I want a clean install/sensor list of everything...
        here is my door controlled light...
        I had it where someone would open the door but someone call them and they would close the door and light would stay on so trigger motion too took care of that...
