I'm going there now!
Thank you!
Kevin
Thank you!
Kevin
[Settings] Guestview=0 PageTitle="Concord 4 Alarm Panel" PageWidth=99% PageCenter=1 ColumnNumber=30 Column1Width=30 Column2Width=30 Column3Width= Column4Width= PageRefresh=0 PageRefreshTime=60 RemoveLogoBar=0 RemoveLinks=0 UseFooter=0 ClassTypeHeader=tableheader ClassTypeSubHeader=tablecolumn ClassTypeLeft=tablerowodd ClassTypeRight=tableroweven ClassTypeRightExtra=tablerowodd ClassTypeButton=formbutton ButtonSize=10 Buttonspacing=1 UseStylesheet=0 CSSName= HeadData= BodyData= ***** Column 1 Section 1 ***** Column1Heading1="Concord 4 Panel" Column1Heading1SpacerTop=0 Column1Heading1SpacerBottom=3 Column1Heading1Height= Column1Section1Spacer=1 Column1Section1VerticalSpacer=1 Column1Section1LeftAlign= Column1Section1RightAlign= Column1Section1RightExtraAlign= Column1Section1WidthLeft= Column1Section1WidthRight= Column1Section1-1Left=Alarm Status Column1Section1-1Right=Device\2 Column1Section1-1RightExtra=DLC\2 Column1Section1-1Height= Column1Section1-2Left=Chime Column1Section1-2Right=Device\3 Column1Section1-2RightExtra=DLC\3 Column1Section1-2Height= Column1Section1-3Left=Last Trip Column1Section1-3Right=Device\5 Column1Section1-3RightExtra=DLC\5 Column1Section1-3Height=
