Jon00 Homeseer 2 web page (Quick view) builder Version 2
    #61
    Make sure you have these two values in your ini file:
    RemoveLinks=0
    RemoveLogoBar=0
    Do you see 2 copies of the logobar, the existing and the one created by BPVal50?
    Jon
      #62
      aight got my quickview page done..
      next is the roomview.. more detailed and each device in each room...
      I cant wait for a plugin for the concord 4 alarm!!!!!
      piperpilot!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
      then I would add
      9 windows
      3 doors (2 are already done with ds10a)
      2 glassbreaks
      2 smokes
      alarm status and stuff...
        #63
        Looks good! Your Computer status icons etc may look better if you align them to the left (IMO only).
        Jon
          #64
          RemoveLinks=0
          RemoveLogoBar=0
          I did go through and add the ini lines that you added to the new version. I have both of those set to 1, since for this page i really didn't want links or the logo bar.
          The little mini called from BPVar50 is still there oddly enough. If i set the
          RemoveLogoBar=0 then I get two logo bars, the real one, and the little mini one called from a variable I don't have. It's like it reads my mind on what I wanted to be there.
          Now that's what I call home automation.
          Marty
            #65
            Doh - I've just thought. They are saved in HS variables. Reboot HS and it will go.
            Jon
              #66
              In V2.03, yes.
              Use DLT(Housecode) in the text - similar to DLC(Housecode)
              any way possible to format that? it is in minutes... at 28876 minutes just doesnt look right....
              I think this is where the basics are nice with this page as you even said that the more difficult stuff are not really possible..
              my quickvew.asp page uses a function... example..
              Function DeviceTime(RoomName,Device)
              response.write "<tr>"
              response.write "<td class='tablerowodd' width='35%'>" & RoomName & "</td>"
              strVar = hs.DeviceString(Device)
              response.write "<td class='tablecellcustom' align='center' cellspacing='0' cellpadding='0'>"
              response.write  strVar & "</td>"
              strVarTime = hs.DeviceTime(Device)
              strHrs = strVarTime \ 60
              strDys = int(strHrs / 24)
              'substract the number of hours in days from total hours
              strHrs = strHrs - strDys*24
              strMins = strVarTime Mod 60
              'pad out then take rightmost digits
              strMins = right("00" & strMins,2)
              response.write "<td class='tablecellcustom' align='Center' cellspacing='0' cellpadding='0'>"
              response.write  strDys &  ":" & strHrs & ":" & strMins
              response.write "</tr>"
              End Function
              and in my .asp file I utilize it as follows:
              for my motion section:
              '>>>>>   MOTION SENSOR TABLE<<<<<
              response.write "<table border='0' cellpadding='0' cellspacing='1' width='100%'>"
              response.write "<td class='tableheader' colspan='3'>Motion Detection</td></tr>"
              NewTime = DeviceTime ("Garage","G16")
              NewTime = DeviceTime ("Utility Room","B2")
              NewTime = DeviceTime ("Basement","[10")
              response.write "</table>"
              response.write "<br>"
              '-----  End Motion Sensor Table Table  -----
                #67
                (IYO) - you were correct.. looks alot nicer!!!!!!!!!!!!!!!!!!!!
                now off to the room view...
                  #68
                  End Function
                  I'll add another variable formatted in this way in the next version.
                  Jon
                    #69
                    sweet so it is possible!!!! Thanks dude....
                      #70
                      Well the DLT variable is done that way - just needs extra formatting!
                      Jon
                        #71
                        After re-booting the HS server it stopped reading the PBVar50. the only think I can think of is it was in a cache over there and somehow wasn't really using the new buildpage. Did i read somewhere that VB scripts just stay in memory until next use, perhaps that was it.
                        After the reboot my mini logo bar was gone I added it back into the new buildpage and it's back.
                        Small mystery solved.
                        Marty
                          #72
                          Marty,
                          A Homeseer variable is a place where you can store information which is available to any script or plugin. Once set, it will remain in memory until it is either cleared (HS restart) or changed by the script etc. As there was no entry in the buildpage.vb script to set/clear it, it just stayed in memory.
                          Telefragger,
                          I've added your request. You can actually display it in two modes:
                          3:12:33
                          or
                          3 Days 12 Hours 33 Minutes
                          You will have to wait until I release it as I'm just waiting a few more days for anything else to crop up!
                          Jon
                            #73
                            Telefragger,
                            3:12:33
                            or
                            sweet... i can wait... I guess....
                            anyhow... so I can even get the time in short form for uptime... that is cool.. .as I dont need that one so long..
                            also I started working on my room view... gonna be 3 rows wide.. have to draw it out as it is combersome....
                            ~Jeff
                              #74
                              well now I got my roomview done...
                                #75
                                looks great but why are the three columns all at different heights? Artistic flair?
                                Jon
