Originally posted by Pete
View Post
Radio Shack IP Cams for $25
Moskus,
No luck yesterday afternoon; will check today locally.
Here's a side by side Trendnet ($69 on sale) and NorthQ (RS with FW upgrade) this morning with ZM. Notice that the Frame rates are about the same. Picture is a bit more crispy with NorthQ. BUT Trendnet is facing the East and NorthQ is facing the West and both are in my window sils behind a screen. The NorthQ is a bit more sensitive to ambient light than the Trendnet.
They are going fast. Called about 12 RS's this morning and none had the cameras.- Pete
Just came back from a store nearby (16 miles). They had 4 in stock. I purchased one to give it a try. I may go back tomorrow if I get this one working.
Steve QHomeSeer Version: HS3 Pro Edition 3.0.0.368, Operating System: Microsoft Windows 10 - Home, Number of Devices: 373, Number of Events: 666, Enabled Plug-Ins
I was able to flash the camera EPROM per the instructions from Pete.
Although not mentioned by Pete, I also had to install 2 "activeX" components (when prompted) from the NorthQ web site. Everything worked smoothly.
I now have the camera up and running and streaming video to my iPhone.
This is the best $25 investment I have ever made!
Thanks Pete for sharing the info about this Radio Shack deal!!!!
I purchased the wireless Trendnet for $69 on sale. Its similiar in quality to this IP camera.
I haven't tested it in wireless mode yet.- Pete
One of the RS stores I called this morning is in Munster, IN.
The person answering the phone stated that their store doesn't carry anything security related?
I'll keep checking in my area to see if there are any around.- Pete
No RS cams in my neck of the woods, mangers I talk to said they were all pull two weeks ago and ship out to eastern states.-Mike-
-Home automation powered by the wind and sun-
Zotac 9300g-Q9400s-4gb ram-Intel 120 SSD-MS XP
HS 2.5.0.20, BLlan,BLweather,MCSXap,Jon00 graphing,Jon00 Whois,Snevl/Ten WeatherAlerts
W2c,Ztroller,z-wave+18,Q100D's,Silex 3000gb
Zoneminder 1.24.2 - Ubuntu 11.04 x64 on top of Xenserve
Zoneminder 1.24.2 - Ubuntu 11.04 x64 Zotac D525 atom
Originally posted by raptorsss View PostSlow day at work today, so I have been logging on to the home network and testing. I have the streaming working in WebcamXP7, Vitamin D, and Blue Iris. But, not direct into a webpage. Will try HS Touch when I get home. Dont have access to the designer from here.
Originally posted by Steve Q View PostI have an older version of WebCamXP; it does not list the NQ9006 as an IP camera. Is it listed in your version of WebCamXP? If not, what camera did you choose?
Steve Q
For new camera, use IP Camera (jpeg/mjpeg) located in the same menu as the USB cameras.
Then set up manually in Raw URL mode.
Address would be http://address/img/mjpeg.cgi
Check the mjpeg box
Make sure to hit the Save button. OK does not save.
