Could someone help me connect the rain8net pro with the sena ls100, both of them bought from Homeseer.
The rain8net works fine when connected directly to com port.
I have not yet been able to get it functional connected to the Sena LS100 Com/IP redirect device
Could you comment on the following parameters which I have to set in the Sena LS100 redirect device?
Mode of communication
Should device be set as a TCP Server a TCP Client or a TCP Server/Client?
Currently it is set as a TCP Server/Client with the following parameters
listening_port = listening TCP port = 6001
dest_ip = destination IP address = 192.168.1.105
dest_port = destination TCP port = 7001
cyclic_connection_interval = cyclic connection interval in minutes = 10
inactivity_timeout = inactivity timeout in seconds = 300
Serial Port Configuration.
baudrate: 1200, 2400, 4800, 9600, 19200, 38400, 57600, or 115200 = currently set to 4800
data_bits: 7=7-bits / 8=8-bits = currently set to 8
parity: n=none / e=even / o=odd = currently set to none
stop_bits: 1=1-bit / 2=2-bits = currently set to 1
flow_control: n=none / h=hardware = currently set to none
dtr_option: h=always high / l=always low / s=show tcp connection = currently set to show tcp connection
dsr_option: n=none / a=accept only by high / o=open,close TCP connection = currently set to none
interchar_timeout: inter-character timeout value in milliseconds = currently set to 10
Are there any other parameters that I should pay special attention to??
