Compiler error
    Compiler error
    I had to reinstall the client software (Speaker/Script/Bluetooth clients) on a Windows 7 client and I get the following error when trying to execute remote_monitor_power.cs
    line:8 error:CS1519 'Invalid token 'using' in class, struct, or interface member declaration'
    I'm running Plugin 1.23.2.4. This was working fine before the reinstall.
    Then I went to my 'everyday' computer where I don't use the script client often, but I get the same error??
    Any ideas?
    The cs file contents look exactly like the version posted here when updating to add ON and OFF parameters.
    Can you post the script you have on your computer ?
    It looks you have a using statement in the middle of the script Line 8
    stipus
      Here's the script. The error is referring to the #USING command
      //If you invoke this script without any parameter, it will turn on the monitor.
      //You can also invoke with the following parameters:
      //- ON
      //- OFF
      //- LOW (low power mode)
      #USING System.Runtime.InteropServices
      [DllImport("user32.dll")]
      public static extern int SendMessage(IntPtr hWnd, uint Msg, int wParam, int lParam);
      void Main( object param )
       IntPtr HWND_BROADCAST = new IntPtr(0xffff);
       uint WM_SYSCOMMAND = 0x0112;
       int SC_MONITORPOWER = 0xF170;
       // WAIT TO LET DESKTOP SETTLE
       System.Threading.Thread.Sleep( 500 );
       switch( param.ToString().ToUpper() )
        case "ON":
         SendMessage( HWND_BROADCAST, WM_SYSCOMMAND, SC_MONITORPOWER, -1 );
         break;
        case "OFF":
         SendMessage( HWND_BROADCAST, WM_SYSCOMMAND, SC_MONITORPOWER, 2 );
         break;
        case "LOW":
         SendMessage( HWND_BROADCAST, WM_SYSCOMMAND, SC_MONITORPOWER, 1 );
         break;
        default:
         break;
        Try to remove everything before the #USING
        --> so that the #USING is on the first line of the script
        stipus
          Well that works.
          Not sure why, as I didn't write the script - it came with the script client. Did MS change parsing rules?
          Either way, it's working now. Thanks for the help!
