Yes, IP Cam Viewer streams live video from any of your IP based or CCTV cams. The dev is always adding more cameras to his list - pretty impressive list too. So I have a Dahua 8 channel DVR with 4 CCTV cams as well as 3 IP based cams, 2 Trendnet and 1 Foscom. All of which I've configured to view in IP Cam Viewer, all streaming with PTZ support as well.
As far as the command line simply typing "IP Cam Viewer" - (the apps name) worked. Took me forever to figure that out as I couldn't believe it would be that simple. I actually found a post here with the solution.
http://board.homeseer.com/showthread...02#post1026302
