Ok so I just spent 3 hrs searching online cuz i cant figure it out.. and got no where.
so I found one thing and I got somewhere... so now I usually ditch it and say screw it.. but my HS is not setup.... want it setup... and starts with my alarm...
so i found something so absurd that i thought i would try it...
IF YOU JUST NEED TO RESET YOUR DEALER CODE BACK TO 4321 DO THE FOLLOWING....
im not sure what happened... i didnt unplug the battery.. making me wonder if my battery backup is bad.. so will have to hit it with a meter later...
but once i removed the eprom (lil 8 pin chip) and put it back in.. the system went into a sensor test.. took 15 minutes i believe...
then i was able to use 8+4321+0+0 to get to system programming
NICE!!!!!!!!!!!!!!!!!!!
since i couldnt find this anywhere on google thought id add it here..
- unplug alarm from outlet
- locate eprom
- remove eprom
- wait 2 minutes
- can verify as keypad will do nothing by trying options
- plug prom back in
- plug power back in
