I'm up and running with the new version. Looks good so far.
Steve Q
Steve Q
Public Sub InitMessageFile() Dim sPath As String If tsoTrace Is Nothing Or gPriorDayOfWeek <> Now.ToString("ddd") Then gPriorDayOfWeek = Now.ToString("ddd") sPath = gHomeseerPath & slash & "Data" CreateFolders(sPath) sPath = sPath & slash & PLUGIN_NAME & ".txt" If System.IO.File.Exists(sPath) Then System.IO.File.Delete(sPath) End If tsoTrace = New tsoNet(sPath) End If End Sub
