I am attempting to launch a HsScript from a backup application. I want the backup application to trigger the HsScript upon completing the backup.
The HsScript application, and script I want to run, are working fine if triggered from the CLI or from a batch file.
hsscript homeseerscript.vb
I cannot get the command to run from my backup app. I believe it is using the 'WshShell.Run' call so I created a vbs file to simulate:
Set WshShell = CreateObject("WScript.Shell")
WshShell.Run chr(34) & "hsscript homeseerscript.vb" & chr(34), 0
Set WshShell = Nothing
When I run this script I get an error explaining that 'the system can not find the file specified'. I believe the script is unable to find the 'homeseerscript.vb' file. I have tried referencing the full path but this does not help.
If I remove the reference to the 'homeseerscript.vb' as follows I don't get any errors.
WshShell.Run chr(34) & "hsscript" & chr(34), 0
The path to the hsscript.exe is configured in the system environment variables so I don't think there's a problem finding the executable.
Any ideas would be appreciated.
