Jon00 Remote Computer Control & Network Monitor (HS2, HS3 & HS4)
    Try the released version.
    The only issue (that I believe I have fixed) was the web page config. It's no big deal as people can still use the old manual method to configure. I figured that people might like the new functionality, especially the client speed increase!
    Jon
      Don't you ever sleep? I just posted and you've already responded!!
      --Dan
        Do you normally sleep in the afternoon? (it's nearly 2pm here). That's the beauty of email notifications from this board!
        We are being battered with 60 MPH gusts of wind and rain here ATM - so staying in!
        Jon
          that is right, you are AHEAD in time...not AFTER...sorry, got my + and - wrong!
          --Dan
            Originally posted by jon00 View Post
            If you look at the first column (Device), how many have numbers against them?
            You may have old data in the ini file as well. Perhaps you should delete all entries under [device14] upwards.
            Sorry Jon, had to work today (that will keep Dan happy )
            When I came home and I looked at the aspx page, suddenly all devices are in the right spot and all devices are numbered from 1 to 13. It seems that everyhting has been corrected now...
            The only thing (very very minor) bug is the status of my iPad. The text in the stats site of Homeseer says that it is offline (which is correct as my wife took it with her) but the graphical depiction shows that it is online (green flag). When I came home I looked everywhere but did not manage to find it. After closer inspection I saw on the aspx page that the icons are in the wrong order. So had a closer look at the HSPRO / html / images directory and there the icons are in the right order...
              If you are using an old version of the ini, look under:
              [Iconset26]
              It should look like:
              Up/down may be reversed
              Jon
                HOLY COW! Finally got the new verson installed!
                The HTPC remote control setup I had is now almost INSTANT!! I LOVE IT!!!
                Thanks again!!!
                Sorry I never had time when this was "beta"!
                --Dan
                  Jon,
                  was playing around with this more and more.
                  Love how fast it is.
                  I"ve noticed I'm getting a LOT of these now:
                  Jon00_RCCNM [Device1] Cannot connect to client on port 8000
                  Everytime I see this, whatever I've got scripted does not get executed. Any idea?
                  --Dan
                    Someone else has reported this, however I have not seen it happen here. Are you sending multiple calls to the client from a script by chance?
                    Jon
                      yep:
                         if( hs.Runex("Jon00RCCNM.vben","main",parm & "||checkprocess||vlc") = "1:1") then
                            hs.Runex("Jon00RCCNM.vben","main",parm & "||sendkeys||N")
                         else
                            hs.Runex("Jon00RCCNM.vben","main",parm & "||sendkeys||ESCAPE")
                            hs.Runex("Jon00RCCNM.vben","main",parm & "||cursorpos||65||633||||0||")
                            result=hs.Runex("Jon00RCCNM.vben","main",parm & "||getcursorbgcolor")
                            ' we are at the end of the show, and we now see "Netflix Red" on the screen
                            ' we are on the red screen
                            if(result = "8B181A") then
                               hs.Runex("Jon00RCCNM.vben","main",parm & "||sendkeys||F")
                               if(parm  = 1) then
                                  screenPos = "600||430"
                               else
                                  screenPos = "800||500"
                               end if
                               hs.Runex("Jon00RCCNM.vben","main",parm & "||cursorpos||" & screenPos & "||1||left||0||")
                               'hs.waitsecs(2)
                               'hs.Runex("Jon00RCCNM.vben","main",parm & "||sendkeys||F")
                               hs.waitsecs(6)
                            ' we are widescreen
                            elseif(result <> "000000") then
                               if(parm  = 1) then
                                  screenPos = "128||675"
                               else
                                  screenPos = "300||815"
                               end if
                               hs.runex("Jon00RCCNM.vben","main",parm & "||sendkeys||SPACE")
                               hs.Runex("Jon00RCCNM.vben","main",parm & "||cursorpos||" & screenPos & "|1||left||0||")
                               'hs.Runex("Jon00RCCNM.vben","main",parm & "||cursorpos||" & screenPos & "|1||left||0||")
                               hs.waitsecs(6)
                               hs.waitsecs(2)
                            ' we are normal screen
                            else
                         '      hs.Runex("Jon00RCCNM.vben","main",parm & "||cursorpos||250||680||1||left||0||")
                               hs.Runex("Jon00RCCNM.vben","main",parm & "||cursorpos||230||680||1||left||0||")
                               hs.waitsecs(6)
                               hs.waitsecs(2)
                            end if
                            hs.waitsecs(2)
                            hs.Runex("Jon00RCCNM.vben","main",parm & "||cursorpos||750||525||||0||")
                         end if
                      Basically, IF VLC is running, send an "n" for the next "thing" in the queue. Otherwise, assume it's Netflix running. If that's the case, look to see what type of screen is being displayed (16:9, 4:3, etc). By that, we can determine WHERE the buttons are located. Then, click with the mouse.
                        Brilliant, perfect, all great features. I love the new web interface.
                        Aldo
                          Originally posted by drozwood90 View Post
                          yep:
                             else
                                   if(parm  = 1) then
                                   else
                                   end if
                                   'hs.waitsecs(2)
                                   hs.waitsecs(6)
                                ' we are widescreen
                                   if(parm  = 1) then
                                   else
                                   end if
                                   hs.waitsecs(6)
                                   hs.waitsecs(2)
                                else
                                   hs.waitsecs(6)
                                   hs.waitsecs(2)
                                end if
                                hs.waitsecs(2)
                             end if
                          Wow - that is quite impressive. The issue is that the client is probably still responding to the previous calls.
                          Things you can try:
                          1) Wait for a result by changing all script calls to Result=hs.runex("Jon00RCCNM.vben","main",parm & "||.....
                          2) Use Macros or Macro21 to carry out most of your local tasks. This will reduce the number of calls to the client.
                          3) Go back to the previous slower client connection method. If you have just downloaded this, check out the Q & A section in the docs.
                          Jon
                            Aldo
                            Jon
                              can macros perform logic? I thought they could only do a group of "things"?
                              I tried to FORCE it to wait by ading result=[command]. That did not seem to help. Are you using UDP or something? IS that how you made it faster?
                              I tried the "old" ClientConnectMode=1, that works, but wow, SLOOOW...especially after seeing what is possible. I'll keep playing.
                              --Dan
                                No, Macros do not perform logic, however you have a number of things which could be grouped together. With a slight bit of reprogramming, you could do much more locally with a few macro calls.
                                i.e.
                                PHP Code:
                                 if(result "8B181A"then
                                         hs
                                .Runex("Jon00RCCNM.vben","main",parm "||sendkeys||F")
                                         if(
                                parm  1then
                                            screenPos
                                "600||430"
                                else
                                screenPos "800||500"
                                end if
                                hs.Runex("Jon00RCCNM.vben","main",parm "||cursorpos||" screenPos "||1||left||0||")
                                'hs.waitsecs(2)
                                hs.Runex("Jon00RCCNM.vben","main",parm "||sendkeys||F")
                                hs.waitsecs(6)
                                ' we are widescreen
                                         if(parm  = 1) then
                                         else
                                         end if
                                hs.Runex("Jon00RCCNM.vben","main",parm "||cursorpos||" screenPos "|1||left||0||")
                                hs.waitsecs(6)
                                hs.waitsecs(2)
                                      else
                                hs.Runex("Jon00RCCNM.vben","main",parm "||cursorpos||250||680||1||left||0||")
                                hs.Runex("Jon00RCCNM.vben","main",parm "||cursorpos||230||680||1||left||0||")
                                hs.waitsecs(6)
                                hs.waitsecs(2)
                                end if
                                Could become:
                                PHP Code:
                                if(parm  1then
                                            hs
                                .Runex("Jon00RCCNM.vben","main",parm "||Macro10")
                                         else
                                hs.Runex("Jon00RCCNM.vben","main",parm "||Macro11")
                                end if
                                      elseif(
                                result <> "000000"then
                                if(parm  1then
                                           hs
                                .Runex("Jon00RCCNM.vben","main",parm "||Macro12")
                                         else
                                hs.Runex("Jon00RCCNM.vben","main",parm "||Macro13")
                                end if
                                      else
                                hs.Runex("Jon00RCCNM.vben","main",parm "||Macro14")
                                end if
                                Macro10 would be:
                                sendkeys||F
                                cursorpos||600||430||1||left||0
                                Wait||6000
                                sendkeys||F
                                Macro11 would be:
                                sendkeys||F
                                cursorpos||800||500||1||left||0
                                Wait||6000
                                sendkeys||F
                                etc....
                                Using Macro21 would be easier in some respects as you can pick and choose which lines to run.
                                Jon
