HS audio plays on 1 out of 4 HS Touch clients
    I have 4 HS Touch clients deployed on 4 iPads throughout the house.
    HS sound plays on one of them and doesn't play on the other 3.
    Any ideas how to make them all play HS sound?
    RI2
    Do they all show as connected speaker clients on the Network page?
    My iDevices will only show as connected speaker devices when HSTouch is active and the phone is awake. If it sleeps or HSTouch is not in the foreground, the speaker client will cot connect. My Android devices are always connected. This is an Apple problem, not HSTouch.
      All you say is applicable to my iPhone HS app. It "speaks" HS only when connected and in foreground.
      The 4 iPads I mention here in this thread are dedicated to HS ONLY. They do not serve any other purpose. They are always connected to HS and always active in the foreground.
      I'm running HS2 so I'm afraid I do not have the reports you are showing.
        Relating to HS2 Touch make sure you are using the last updates posted:
        1 - HomeSeer Version: Professional Edition 2.5.0.81
        2 - HSPI_HSTOUCH.dll 1.0.0.72
        3 - HSPI_HSTOUCH_IPHONE.dll 1.0.0.2
        I do not utilize HS2 HSTouch anymore having switched over now to HS3 Touch.
        I also was running HSPI_HSTOUCH_UNLIMITED.dll 1.0.0.1
        The HSTouch 2 clients appear as:
        Host : Instance
        Do you see all four iPad clients?
        I am supposing as they are dedicated to HS2 they are all on the same internal network in the house and you can see from them and to them.
          Thank You Pete.
          Yes I see them all. Below is what I see under "Speaker clients" in HS2 Setup menu at the bottom
          The first one is my computer where I run HS Speaker client. The rest are my iPad controls.
          Everything seems normal and yet only one of the 4 iPads plays HS Sound. The others are silent.
          Speaker Client network port (8737 and 8739 cannot be used):
          8742
          Default Comma Separated Host:Instance List for Speak Commands (Leaving Blank = All Clients):
          Example: HomeSeerefault, Kitchen:*, Bedroomaytime
          Host : Instance
          IVANOFFICE (192.168.1.242) : DEFAULT
          hristo (HSTouch) : hristo
          ivan (HSTouch) : ivan
          ivan2 (HSTouch) : ivan2
          ivan3 (HSTouch) : ivan3
          Save your changes
