Help, can't get script running from remote computer
    Never Mind, I got it working...
    I recently ran into some malware on my non-homeseer PC that wiped out my quick launch toolbar. On that toolbar I had icons set up to toggle a couple of lights when I clicked on the icon. I didn't have backups (Yeah, I know my bad ) of the quick launch links and am having trouble re-creating them.
    This worked in the past. I have the script connector and speaker software installed on the remote PC and they seem to start up and connect with my Homeseer server just fine.
    I set up the shortcut as follows:
    Target: "C:\Program Files\HomeSeer 2\HsScript.exe" den lamp on-off.vb(s)
    Start In: "C:\Program Files\Homeseer 2\"
    I have tried it with two script files;
    den lamp on-off.vb:
    Sub Main( param as Object )
    if hs.isoff("P1") then
    hs.ExecX10 "P1","on",0,0
    else
    hs.ExecX10 "P1","off",0,0
    end if
    End Sub
    den lamp on-off.vbs
    Set hs = CreateObject("HomeSeer.Application")
    else
    end if
    When I run either one I get a "Requested Service not found" HsScript.exe error message box.
    Any idea what's wrong?
    Dick
    HS PRO 2.5.0.81, WinXP, IE8, Shuttle XS35V3, 2.13GHz, 4GB, 40GB SSD drive, AC-RF2, ADIOcelot, Message Server, TI103, SNEVL CID, pjcOutlook, MCSTemperature, Powertrigger, BLBackup, BLFloorplan, BLIcon, BLOccupied, BLRadar, BLRfid, BLLogMonitor, ACPUPSD, UltraECM, WeatherXML & Stipus' script connector. 500+ devices, 260+ events, 1-wire weather station + temp/humidity sensors & Oregon Scientific temp & humidity sensors & 2 Brultech ECM-1240s
