Radio Shack IP Cams for $25
    Trnednet Wireless
    Not quite as good a deal as the Schlages for $25, but CompUSA has the Trendnet Wireless on sale for $50.
    http://www.compusa.com/applications/...&Sku=T156-2414
    -Dave
      Good deal Dave. I've been playing with that model and its working well. Just recently they also had the 120 model with wireless and IR lighting. Going to try that one where the Foscam is to see how it works. I like the small footprint. For those wanting to utilize the Trendnets outdoors Trendnet makes an outdoor housing with a small heater...but its $100.
        -Dave
        Bummer...
        Sales is over now...
        Transitioning to HS3Pro .298 - WinXPEmbedded
          Pete, thanks for your email suggestion, it worked like a charm.
          Aldo
            Good news Aldo; STunnel has worked well for me for quit a few years now.
              Hey Guys,
              So I have moved 4 more cams from the Shack into my production environment. All flashed ok with NorthQ software. Here is a question, since I can't get the netcam to ever pull images, I poked around and found this:
              http://www.northq.com/docs/NQ9006-Install.zip
              It is a stand alone NVR software that I would like to use on the Home Troller to store video on the NAS that is hooked up.
              Has anyone got this to work yet?
              Also, anyone gottent he motion triggering working on it? The wireless versions do not seem to support it but the wired ones do for some reason...
                Steve,
                I tried to get it to work with Netcam and could not.
                Here's a short script; see if this works for you.
                Create a directory under Homeseer HTML called radioshack.
                Sub Main(parm as object)
                Dim S As Object = hs.GetURLImage
                ("http://IPOFCAM/","/img/snapshot.cgi",false,80,"html/radioshack/radioshack.jpg")
                end sub
                  Anyone using this camera with Vitamin D Video? If so, what settings are you using....
                    OK, I have the NVR software downloaded from NorthQ working!!!
                    You will need to use the internet settings and not the LAN settings so you will have to give your cams access to the web. I use DynDNS and lock the cams out with PW's and it works just fine.
                    Here is a screen shot of the setting screen:
                    Here is what you need to enter:
                    1) Check that "Internet" is selected not "lan"
                    2) Enter any device name you want here, no spaces - keep it short like "KitchenCam"
                    3) enter "yourdyndnsdomainhere.dyndns.com" <-- or whatever you use. No http, no port, just the plain name. This is if you install the NVR on a computer not in your LAN.
                    3a) if you have static IP's on all these cams, put in the IP itself there. Example, 192.168.1.100. These DO NOT need to be publically routable if you do not have access to these cams over the web but, can be the public IP's if that is what you use.
                    4) put in the port that you configered in the GUI if you changed it from 80.
                    5) Put in the cam's username that you built in the GUI. If you do not have username enabled in your cam, you can leave this blank.
                    6) As as above but for password
                    7) Leave the stream type MPEG4
                    8) Check "Enable Tigger Event"
                    9) Cleck the "test" button. If you get "Test Successful" you are done, click the "add" button. If not, check the settings and try again.
                      FYI, I picked up one of these in a wireless flavor the other day for 39 bucks, so if that is something you are interested in check and see if there are any left. The only problem I have with these cameras is no night vision. Going to have to use the Foscams for that I suppose.
                        Wholly crap! That is a smoking deal. They are still 80 bucks here in CA!
                          Anyone got these working with either Webcamx or Vitamin D? What settings are you using?
                          thanks
                            Yes, I use them with WebcamXP. You can set them up as a Linksys Wvc54gca (mjpeg). I heard that someone on this board, (maybe this thread), had contacted the Author of WebcamXP to make a specific template for this camera. I don't know if that happened.
                            - Tom
                            HSPro/Insteon
                            Web Site
                            YouTube Channel
                              All - Thanks for sharing your finding. I was able to install and get the NVR software working. I used the lan configuration without issues. Did you get the motion detection to work? On mine, It works via the IE Web tool but it does not work via the NVR software. I like these cameras, nice cool application as well.
                              Vitamin D would be the next step.
                              Aldo
                                Picked up 2 today - looking forward to modding!
