Caller ID - UK
    #16
    Originally posted by Traction Tim View Post
    Hi Greig,
    I can't see how to test CID with the test wizard. Can you explain what you want me to try ?
    I did find the Way2call tapi setup, and that shows this:
    if you start the test wizard then make a call do you get CID in the window of the wizard.
    Can you also click on the advanced button in the tapi setup window you sent a screen shot of and then send me that as it has CID settings.
    Thanks for your help I hope we get this worked out.
    Greig.
    Scripts =
    Various
      #17
      Hi Greig,
      I did try calling the house phone with the wizard running, but I didn't see any caller ID in the test wizard window - I couldn't find a specific test for an incoming call. Do I have the right test program ? (See image below).
      The advanced window for TAPI looks like this:
      Win 11 Pro | HS4 Pro | Z wave plug in with UZB1 | BLUSBUIRT 2.0.11.0 | RFXtrx433 | Blue Iris CCTV | VU+ 4k with motorised dish | Emby | Hi-Phone HS2 | ESP32 with WLED |
        #18
        Yep that is the same program. If you call do you not get the fact that it is ringing displayed in the window? I thought my system showed that up and that is why I wondered if it showed CID in your version. Did you click go first?
        My settings are the same as yours so far so no luck.
        I was just thinking I have a Dev system that I have not used HSPhone on or messed with the files so I will try and move the modem on to it to see if it works in there and this will tell us if it is HS or something else.
        I am working all day today and tomorrow but will have time on Monday so will do this then.
        Sent from my HTC One using Tapatalk
        Scripts =
        Various
          #19
          Oops sorry double post.
          Scripts =
          Various
            #20
            Hi Greig,
            I'll give it another try when the Missus wakes up
            Tim
              #21
              Hi Greig,
              Success with the Way2call test wizard test. It does indeed show the CID (Number altered manually for this post !) after pressing GO and skipping the test:
              F/W Version=4.03.36
              S/N=HD00USGR02102430016035
              Caller-ID: Name=[] Phone=[07707123456]
              ***** Incoming Call ! *****
              Over to you !
              Tim
                #22
                Hi Greig,
                Over to you !
                Tim
                Great thanks that narrows it down to not being HS.
                I will test some more when I get a chance.
                Greig.
                Scripts =
                Various
                  #23
                  Good luck Greig,
                  We should have ITGuys script working by the time you have sorted your system.
                  Tim
                    #24
                    It Works!!!!!
                    I have had my hose in bits getting this going only to find out it is not the W2C or HS. I am using a USB server that I used with the W2C and HS2 with no problems but for some reason if I bypass it and run a phone extension to the server it works.
                    Thank you so much for your time and effort helping me. I should have tested this before but I thought it worked before why would it not work now!
                    now to install ITGuys script.
                    Wish me luck.
                    Greig.
                    Scripts =
                    Various
                      #25
                      Greig,
                      Good news indeed ! What a strange one though
                      Now for that script. It's a work in progress, and it doesn't work quite as it should yet. More testing required
                      Tim
