Originally posted by Jakob.Sand
View Post
Arduino Plugin V1.0.0.36.
Originally posted by will40 View PostHi Greig
I want to setup a second board. I have a mega 2560 with a wifi shield. Do you have a sketch written for a wifi shield to replace the Ethernet sketch you could share with me?
Will
Sorry but I do not have a WiFi shield as when I looked at them I found them to be very expensive for what they did. I have it on my list of thing to do to get some kind of wireless device working with this.
I know there are users using the Ethernet shield and a WiFi games adaptor that works but I seem to remember them saying that the connection drops out every now and then.
Greig.
Sent from my HTC One using TapatalkZwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
Greig.
Have you given any more thought to the wireless shield? I would be willing to mail you a wifi shield to help with your development.
Will
Will
Greig.
Scripts = Various
I know it says there is an api for sending custom values but where can I see the information on how to do this? I would like to send the ph and orp of my pool thru serially connected atlas scientific stamps. Want to make sure this isn't past my level of knowledge before I purchase everything.
Arduino Setup not building
Anyone have the issue of adding a new board and the setup screen not being built? I have added board #3 and it adds the board, but the setup drop down never populates. I have tried removing it and adding it again and still no luck, my first board seems to be the only one that populates consistently.
Any feedback would be appreciated.
Originally posted by mlconti View PostAnyone have the issue of adding a new board and the setup screen not being built? I have added board #3 and it adds the board, but the setup drop down never populates. I have tried removing it and adding it again and still no luck, my first board seems to be the only one that populates consistently.
Any feedback would be appreciated.HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Originally posted by mlconti View PostShould be the current version 1.0.0.36HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Originally posted by rprade View PostYou might want to try v1.0.0.103. It is in the BETA section at the bottom of the plug-in management page. There have been a lot of changes since 1.0.0.36 that improve board connection and configuration.
Input issues on Beta
Originally posted by mlconti View PostI tried the Beta plug in and that fixed the issue! Thanks for the advise, I did not think to look to see if Greig had loaded a new beta.
Originally posted by mlconti View PostRunning the Beta version - My input is not updating as expected. I can trigger the input and I see it change (open contact) so 0 volts. I can then close the contact and I show 3.7volt approx on the input yet I have to reset the arduino to get the update. Anyone else seeing this?HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Originally posted by rprade View PostIf this is an analog input, I know there have been some others reporting anomalies. Unfortunately, I do not use analog inputs, so I really cannot help much. If I get some time later this week, I can try on my test board.
Sorry, this is a Digital input - The voltage reading was taken with my volt meter.
