| xAP Discussions Discussion area for the xAP plug-in and the plug-in nodes posted in the xAP Library. |
October 7th, 2009, 04:33 PM
1-Wire .NET xAP Connector
Version 3 of xapmcs1wire has been posted at [ http://board.homeseer.com/showthread.php?t=101056]. This is a .NET implementation that no longer requires the Microsoft JVM. It is based upon the .NET framework and uses J# libraries and the latest 1-wire drivers from Maxim-ic. It has been tested with Vista X64 and XP32.
If you do not already have the prequesites installed they can be found as the following links:
The .NET framework 2.0 needs to be installed http://www.microsoft.com/downloads/d...displaylang=en
The .NET J# 2.0 redistributable needs to be installed http://www.microsoft.com/DOWNLOADS/d...displaylang=en
The 1-wire drivers need to be installed http://www.maxim-ic.com/products/ibu...tmex/index.cfm
For those upgrading I suggest that you install the V3 xapmcs1Wire in a new folder by expanding the zip file. Copy the old xapmcs1wire\config folder to the new location. Everything is backward compatible with the only issue I had was the new drivers identify the DS9097U differently so you will get " Desc=Specified adapter name "{DS9097U}" is not known Line 100 Specified adapter name "{DS9097U}" is not known " message. You can correct this by using the Search for Ports button. The name the new drivers gave for my adapter is DS9097U_DS9480 and I no longer had a default port (i.e. no < and > bracket in the Comm Port(s) box.
Multiple adapters are now fully supported.
The Comm window is now browser rather than form so is can be remotely viewed
A messages page is available from the tray for hard copy of the errors that are also delivered via xAP Homeseer.Event schema.
The browser display contains a set of links at the top. These are read from the \HTML\xapmcs1wire\Links.htm file. You will need to edit this file to put the links of interest to you. My links can be used as an example. The option to use Homeseer Header was not tested as my 1-wire environment is not on the same computer as HS2.
While we are progressing by moving from MSJVM to the .NET J#, Microsoft has elected to voluntarily discontinue J# with the last release associated with the .NET 2.0 framework. This means someday the same issues that we now have with MSJVM will exist with MS J#. This is again a Dallas Semiconductor (Maxim-ic) decision to use J# as it was to use MSJVM.
October 8th, 2009, 07:13 AM
Super Seer
Michael, I am currently running two instances of XaPMCS1Wire. One is located inside of the HS directory and the other one is outside. Are you stating that both of these (new version) should be running outside (autonomously) of the HS directory?
Base HW & SW: P4 2.97 GHz / 1Gig / MS Server 2003 - creating duplicate server
HS Version Pro 2.4.0.11 pending migration to new computer-Mini-ITX based
HAI OmniPro II X 2 @ FW V3.2D (new 3.3 FW is out?)
Powerline: X-10 & Insteon & UPB (testing) Pending Z-Wave - UPB testing begins with 3 switches for now.
Sound - Current 10 pairs of speakers for HS and music- 6 local subzones -AB8SS- readdressing methodologies / HS control - bought a Russound/KPLs to play with for now.
October 8th, 2009, 02:44 PM
My suggestion is that each xAP application have its own folder to avoid any issues of the same file being overwritten by two applications and to make maintenance update configuration control easier. It is only a suggestion.
October 8th, 2009, 09:27 PM
Hi Michael,
I like the new version and happy to see no more of the MS legacy Java (was a pain to always try to hunt down the MSJavaVM after a rebuild.) One issue though, last night it started out ok, but then started giving me the following error in the logs:
10/8/2009 7:24:01 PM mcs.OneWire.MIKEHOME>xapmcs1wire setupds2408 line 30 object reference not set to an instance of an object.
Then it would no longer consistently send updates (only about 2 of my devices would update.) Any thoughts on what it might be and what I could send you to help debug it? I've gone back to the last version of the VB6 plugin and it's ok for now.
Thanks again!
-Mike
October 9th, 2009, 03:43 AM
The DS2408 code is a special case as it talks directly to the adapter rather than going through the Java library. I did not have any of these in my system when testing. Can you give the attached a try.
October 9th, 2009, 07:08 PM
Hi Michael,
Thank you for the quick response, but getting a new location where it's failing now:
10/9/2009 6:06:45 PM mcs.OneWire.MIKEHOME>xapmcs1wire setupds2408 line 80 object reference not set to an instance of an object.
-Mike
October 9th, 2009, 08:03 PM
This should take care if it.
October 9th, 2009, 08:45 PM
Super Seer
Michael,
got the new 1wire connector online. I like the filter feature!
question: is the config\includes.ini file still used? If so, is it possible to turn off the 1wire banner across the top?
Below is what i have in my includes.ini file now. what do i need to change?
also,i notice the app creates a empty mcsXap.ini in the config folder, but nothing is written, is this old? the app also creates a Data\xapmcs1Wire folder with nothing in it? some of these extra files and folder make it a little confusing to know where important files go.
[HEADER.ASP]
;hide the 1-wire status bar
HIDETITLE=1
;LOGOIMAGELINK=https://homeseer.sandler.org/stat
LOGOIMAGELINK=NONE
;STRLOGOYN doesn't seem to do anything
STRLOGOYN=No
;STRSHOWLINKS turns on and off links.html or oldstyle
STRSHOWLINKS=No
LINKSLOCATION=Yes
STRREFRESH=0
USEPAGESCROLL=0
USESECURITY=none
HS 2.4.0.11 (Standard)
Hardware: Insteon PLM | Powerlinc USB | HAI RC80b | W800RF32A | USBUIRT | 1-Wire MasterHub | AD2USB
Plugins: Insteon | Powerlinc | HAI RC Tstat | ACRF2 | UIRT | mcsXAP | Vista Alarm (mine) | Switchlinc Programmer (mine) | DooMotion | PowerTrigger (disabled)
Scripts: Quickview | Virtual Graphing | WeatherXML | SNMP UPS Monitor (mine)
Platform: Windows 2003 Server, 3.4Ghz, 3GB memory
October 9th, 2009, 08:56 PM
Hi Michael,
Getting closer  It's no longer erroring out. However updates still aren't working correctly. It will send some devices pressure sensor, lightning counter, but it's not updating temperature, wind speed, etc. It also won't send updates to my hobbyboard LCD. If I switch back to the VB6 version (with the same ini) everything instantly starts working.
Thanks again!
-Mike
October 9th, 2009, 09:24 PM
mloebl,
I will be gone until the middle of next week and when I return I can connect my LCD to test out this portion of the code. It is the only segment that was done differently and that was because it was done before the owapi had the DS2408 supported.
The lightning should be a DS2423 counter and wind speed is also a DS2423 counter so it is odd that one would work and the other did not. I was testing wattage and water use for my evaluations. Wind speed sensor was connect, but no wind to measure.
msnandler,
I did not port over the user of the includes to the .NET code. If you can be specific as to what provision you want for formatting (or lack of) then I'm ceratain I can accomodate. I tried to stay within the .NET framework as much as possible and the Inlcudes made use of the COM ScriptControl. I did need to leave the COM ADOX as I do not think there is a .NET way to alter databases and tables on the fly with .NET.
October 9th, 2009, 10:29 PM
Super Seer
Originally Posted by Michael McSharry
msnandler,
no problem dumping the includes. How about a few simple settings in the mcsXap1Wire.ini to
1. enable or disable the banner (the line with the the date/time, sunrise sunset, logo, etc).
2. a second setting to change the location of your "1 Wire Status V3.0.0 Copyright 2005-2009 mcsSolutions" tag line to the bottom of page instead of the top.
Basically I have a custom asp page that puts the homeseer header at the top and uses an iframe to include your status page. I do this so i can see the 1wire status page either locally or remotely and it looks the same.
October 10th, 2009, 01:23 AM
I did what I think you asked for with V3.0.0.2.
October 10th, 2009, 10:34 AM
Super Seer
awesome. works perfectly.
in one your future version (no hurry), can you add one of the icons you use in the system tray app as a resource/default icon for the iwire app.
also, i think i saw you asked a question about dynamically changing a table in a .net app...checkout MS AJAX. This .net extension will allow you to do this.
thanks
October 10th, 2009, 06:46 PM
mloebl,
Hi Michael,
It's possible I wasn't patient enough for the wind sensor (or it wasn't breezy enough.) I'll put it in again to let it run again for a bit to see if it was just me with the temps not coming in. Thanks again!
-Mike
October 10th, 2009, 07:59 PM
I added a dbl-clik event on the icon to show the xapmcs1wire Browser page. I also implemented the Messages and Comm pages with the header options. V3.0.0.3.
Thank you for the pointer on ADOX. It looks like I can use standard SQL syntax to manage tables and fields just as I do for SQL Server even with Access database. When I went to make the change in xapmcs1wire I discovered that I did not have any database operations here so it will be something I explore in the future in another application.
October 11th, 2009, 10:00 AM
mcsxap1wire
Hi mikael,
i am now using V3.0.0.2 on a FIONO 330 with Windows 7 64 bits and it is workink perfectly.
Also, it seems the new Xap plugin isn't going deaf anymore.
Thanks for all the good work.
Claude
October 11th, 2009, 12:39 PM
Super Seer
I switched over to the new XaPMCS1wire browser yesterday. All working well. Thanks Michael!
October 11th, 2009, 06:33 PM
Upgrade v2.7.6 to v3.0.3 = no 'Cal' or 'Poll ms'
Updated to v3.0.3 from 2.7.6 as outlined in your post:
Uninstalled DS9490 using Device Manager
Uninstalled Maxim 402beta driver
Installed J#
Installed Maxim 402 driver
Unzipped xapmcs1wireNet to a new dir
Copied the following ini files from orig Config dir to new Config dir:
- includes.ini
- includes.ini_bck
- mcsXap1Wire.ini
- mcsXap1Wire.ini_bck
- mcsXap.ini
- mcsXapDevices.ini
- mcsXapDevices.ini_bck
Ran xapmcs1wireNet
Fiddled around with ports and finally got it to read my devices.
However, 3.0.3 ignores the 2.7.6 ini settings for Cal, rev and Poll ms.
Two screen shots are included below for your review: the first is v2.7.6 just before the upgrade and the 2nd is v3.0.3 after getting it 'working.'
After reviewing the ini files from both versions, I decided to try from scratch. I removed all files from the Config dir and started xapmcs1wire. After finding the 'com' ports and searching for devices, I saved and restarted. All of these initial settings 'stuck' and a review of the new ini confirmed that the device info was saved.
I then changed the Cal and Poll ms settings for several devices, saved and restarted - these settings did not 'stick' and reverted to 0!
I did verify that the Cal and Poll ms values are being written to the ini file, but they don't seem to get read from the ini on startup...
Any help would be appreciated!
Best regards,
-Mark-
Interested in maps? Check out my company site: Solid Terrain Modeling
October 11th, 2009, 07:24 PM
Did the Messages page show you anything that may indicate why the settings was not being restored. It looks like it got part way though init and then raised an error which should have shown on the Messages Page.
October 11th, 2009, 10:12 PM
Only messages shown are:
10/11/2009 6:03:31 PM | 10/11/2009 6:03:31 PM | Using xAP port 2346
10/11/2009 6:03:31 PM | 10/11/2009 6:03:31 PM | InitINIVariables Line 20 An item with the same key has already been added.
Then, if I change the Cal value for a device and save I get this:
10/11/2009 6:04:34 PM | 10/11/2009 6:04:34 PM | Status ClientRequest Line 1500 Collection was modified; enumeration operation may not execute.
I've attached two ini files:
v2.7.6 (before upgrade)
v.3.0.3 after 1 run, change Cal & poll for 1 device, save then close
Best regards,
-Mark-
| Thread Tools |
| Display Modes |
Linear Mode
HTML code is On
