I have two events that intermittently retrigger after less than the "retrigger" setting and before the condition persists for the "persist" setting
One event compares an upstairs temp sensor with a downstairs temp sensor and looks for a delta that increases above 1. It is not supposed to retrigger for 15 minutes and the condition is supposed to persist for 3 minutes.
Here's an example of these occurrances from HS log:
02/01/2005 8:50:41 PM~!~Temp Info~!~Upstairs/downstairs temperature differs by MORE than 1 degree
02/01/2005 8:51:41 PM~!~Temp Info~!~Upstairs/downstairs temperature differs by MORE than 1 degree
02/01/2005 9:01:42 PM~!~Temp Info~!~Upstairs/downstairs temperature differs by MORE than 1 degree
02/01/2005 9:02:42 PM~!~Temp Info~!~Upstairs/downstairs temperature differs by MORE than 1 degree
The other event compares the same sensors and looks for a delta that decreases below 1. It is not supposed to retrigger for 60 minutes and the condition is supposed to persist for 3 minutes.
Here's an example:
02/01/2005 8:30:40 PM~!~Temp Info~!~Upstairs and downstairs temp differs by LESS than 1 degree
02/01/2005 8:31:40 PM~!~Temp Info~!~Upstairs and downstairs temp differs by LESS than 1 degree
02/01/2005 8:42:41 PM~!~Temp Info~!~Upstairs and downstairs temp differs by LESS than 1 degree
02/01/2005 8:43:41 PM~!~Temp Info~!~Upstairs and downstairs temp differs by LESS than 1 degree
Attached is what I think to be the relevant event entry in HS config file. Let me know if more info is needed.
Here's an example:
