This application is to be used to gather a sample of the logging from your router. Once you have your router set to log to a specific network computer (ie: your HS computer), run this application and let it run for a while, then attach the log file (which is located in the same directory that the application is run from) to the thread titled <a href="http://board.homeseer.com/showthread.php?t=106906">Router Log Samples</a>
UPDATE on 09/15/2005:
I have updated the Router Logger to give me a better format of the logging to test with the plugin.
If you have downloaded it before this, please download and use this version for capturing the router logs.
TIA
TIA
