I installed the WAF Net Caller ID From the updater today.
For the life of me I can not get it to work at all with HomeSeer 2.0 Build 1972
All the files installed correctly in the subdirectories of:
C:\Program Files\HomeSeer 2\
In the WAF-NetCallerID.ini I have the following:
[Settings]
InstallDone=True
i_com_port=10
i_com_port_resource=8
i_hsp_installed=1
i_call_external_script=0
s_script_name=
s_function_name=
s_phone_list_file=WAF-NetCallerID-Phone-List.txt
i_cid_reversed=1
i_cid_comma_delimiter=0
i_enable_logging=1
I have used HyperTerm to connect to Comm #10 when HS is unloaded and verified that I see incoming data when I call the phone number.
The Statup shows:
9/23/2005 9:38:40 PM ~!~Startup~!~Running startup script
9/23/2005 9:38:40 PM ~!~Startup~!~Scripting is OK
9/23/2005 9:38:40 PM ~!~WAF-NetCallerID~!~Script version: 1.1.6 Port opened On COM 10
9/23/2005 9:38:40 PM ~!~Info~!~Done with scripting
9/23/2005 9:38:40 PM ~!~Startup~!~Start up complete.
What am I missing?
[Settings]
InstallDone=True
i_com_port=10
i_hsp_installed=1
s_script_name=
s_function_name=
i_cid_reversed=1
i_enable_logging=1
The Statup shows:
What am I missing?
