Here is the second version. The Scenes page are included. I have only tested these pages with HS2.0 (no earlier versions)
I welcome your feedback
Installation instructions:
1. Unzip the files in the attachment to the folder html/smarthome (the html folder is where your current hs2 installation exists). The smarthome subfolder is required at this time.
2. Add a custom page to the Setup/Web Site page. the Title can be whatever you want (e.g. SmartHome) and the URL/Link should be /smarthome/smarthome.asp
3. Click your new custom button to access the smarthome programming features.
Other information:
Your smarthome device types must have the "uses smartlinc protocol" option check in order for devices to show the Devices page. You must create a device type called "Scene" and assign any scenes (a device of type scene) to that type in order for the scene to show on the Scene page.
The device on-level settings are saved in your config database. So the values will match if you use the existing HS2 Switchlinc Settings page. However the fade rate is not saved by HS2 setting page. I would suggest using my new page as your fade rate settings will be saved in a smarthome.ini file in the config folder.
The Scene page will allow the creation of SH scenes. First create a device type called Scene on the Setup/Device Types page. Then create devices (that have a name, location and a valid x10 address, no virtual codes) of type Scene on the Status/Add Device page. These new devices will then show up in the Select Scene dropdown on the new Scene page.
To program a scene, select the devices to include and set the levels and fade rates. Then click the Set Device Levels btn and wait for your lights to flash. Then click the Set Fade Rates btn and wait for the lights to flash again.
You may remove devices from the scene by clicking the Remove btn. Remove one device at a time.
There are also test btns, Scene On and Scene Off that just send the x10 on/off cmds respectively.
Enjoy!
<!-- / message --><!-- attachments -->
Other information:
Enjoy!
