If had HS 2.0 up and running for a couple of weeks now. All operator error problems solved!!! Now I can't seem to operate the relay outs manually or by command. HS see's the relays, supposedly, and changes status but there is no state change on the relay contacts at the SECU-16. Where is the first place to look for an error. I haven't loaded CMax as I thought it was a very hard program to operate.
