I'm using the Hobby Boards Master Hub for 1-wire. Since this hub isn't supported by mcstemp, I have a need for xap for integration with HomeSeer.
So far, I have
1) xapmcsHub running as a service
2) xapmcs1Wire running as a service
3) mcsXAPplugin installed, ocx registered and using xAP port 32768 and 32770 for mcs.OneWire
And now, I've gotten myself stuck.
When trying to configure xapmcs1wire, I'm finding in Task Manager that the process is toggling back and forth between "running" and "not responding" at 5 second intervals. I can see that the 1wire setup has the correct comm port for the Hobby Boards hub, but I can't change any other items.
In xapmcsHub traffic, I can see the 1-wire port established, but it's delivering a message...OneWireException: 1-Wire Net not available.
So, a few questions.
Am I generally on the right track with the components I need to install to get started (the xapFramework.net site is down)?
If I do have the right components, is this "running-not responding-running " back and forth behavior normal?
What's the next step to getting the 1-Wire Net available to the mcsHub?
Thank you.
So far, I have
Thank you.
