after fighting with this plugin for the last month i just have to say that this plug in sux moose nuts. Great idea but it simply does not work.
this plug-in should be either removed from the 1.7 updater until it is either completed or fixed. (havent tried in HS 2) if it isnt going to be removed then warnings should be posted in the updater in regards to its lack of functionality so that others dont waste hours and hours of there time trying to get this $%^# running.
99% of the time the webpages just freeze up and dont do anything at all.
The instructions are fine but are useless since the programs is incomplete or bug ridden.
i run a site validater (dreamweaver 8) set for vbscript.asp on the entire HS web folder and i get hundreds and hundreds of errors from the hstv folder only.
these are the 2 errors i get
(first one only shows up a few times but the second one shows up atleast 500 times).
& found between tags. Consider using the equivalent entity (& = '&', < = '<', > = '>', " = quotation mark). [HTML 4.0]
Quotation mark found between tags, HTML documents should not contain these values. Consider using (& quot) instead[HTML 4.0]
might be the answer to this actually becoming functional and may not.
