Nevermind, take a look at the attachment, I modified for a single tstat.
I removed the function call and put it all in main, just run the script with no advanced options.
You need to change two things first you need to put your tstats device code in near the top, I have a comment showing you where, replace $1 with whatever your code is.
Secondly, I set it up for t1-t8, you can change those device codes to suit your needs near the bottom of the script. I put a comment there for that too. Didn't test it but it should run fine.
Let me know if you have issues...
G
G
