Please post your comments on this package here. More details here.
Jon00 Picture Viewer discussion
Way To Go Jon!
This is the most awesome plug-in I have ever seen. It blows every web album I have tried and seen away and the best part is it can automatically add new pictures and folders. It has the ability to support guest view and will sort the folder list in alphabetical order and it has many more features.
The Best Part Is It made the WAF go WAAAY up
If you get a chance please give it a try today.
Thanks again Jon for another great product.
Thom
Error
Jon,
I set it up to use photos in a non-HS folder. I can see the pictures locally, but not over the network. Remotely, I can see the place holders for the pictures, but not the pictures themselves.
What am I doing wrong?
SteveLast edited by tikt4u; February 17, 2007, 05:43 PM.
That's most odd - I have my picviewer.ini file setup looking at 2 network machines my picture folders (shared) different from the Homeseer server and they are correctly displaying images in Internet Explorer.
Do you have the shares correctly setup using back slashes i.e.
\\machinename\drive\folder\
Do you use the same username/password on each network machine?
OK,
If you cannot see the pictures in the browser, it has nothing to do with the ASP but rather a permissions problem with your network.
I maybe misleading people with UNC paths. If you get it working then they will only ever be visible on your own LAN on local browsers. If you want to guarantee to be able to view your images locally and remotely, you do need to install all your pictures in a folder under your Homeseer 2/HTML folder. These will be served correctly by your Homeseer web server.
Jon
Is there some way around this.
Thom
Not that I know of.
It's a sensible security issue preventing people using a web server to obtain files not intended for access.
The only way would be to use a freeware folder synchronisation program between a folder outside and within the Homeseer/HTML folder. You would then have 2 copies of the pictures.
Feature Requests
1. Could there ba a sideshow feature where the viewer could be user defined to cycle thru the pictures? Maybe with a start/stop button?
I would like to do this for my servaliance camera's to make a mini move of the slideshow.
2. A page call that would call picviewer without the headers.
Very nicely done.
Paul
I'd like to second that for an option for no header/footer. Would make it ideal to put into touch screen scenes.
Great plugin!Bryan
Software/Hardware: Win10 Pro, HS 3 Pro, HS Touch, Echo, Edgeport/4, Z-Net w/88 Devices, Insteon PLM w/19 Devices, Nest, GC-100-6, W800RF32A, WS-2080 Weather Station (KMADRACU10)
Plug-in/Scripts: Alexa API, BLBackup, BLGData, BLLED, BLLock, BLRF, BLTVGuide, Blue Iris, BLUPS, Current Cost 3P, DirectTV, FitbitSeer, Insteon, Nest, Pushover 3P, Random, Restart, Tasker, UltraGCIR3, UltraWeatherWU, Z-Wave
