Hi amatore,
I think you may be sending the command out to a unit that does not exist...
If you want to send to bus 0, unit 0, then the zone would be 0 (shows blank in HS), not 1 as the log shows.
If you don't care about the unit stuff, the zone should be 99, for all units on bus 0.
I'm not sure if something has changed in the IRTrans.NeT.dll, because I ran into the same thing as you in regards to some of my old commands not working until I relearned them, and I have absolutely no idea why this would be. In my case previously learned commands had no problem being sent out other units. So it's not all commands, maybe just something to do with bus 0, unit 0. I may have to check with Marcus on this...
