| Ultra1Wire HSPI Discussion area for the Ultra1Wire HSPI supporting the HA7E, HA7Net and TEMP08 1-Wire devices. |
February 28th, 2007, 07:19 PM
Ultra1Wire HSPI For HomeSeer 2.2
Ultra 1-Wire HSPI for HomeSeer2
Ultra 1-Wire Features:- Automatically discovers and builds HomeSeer devices for each DS18S20 and DS18B20 temperature sensor.
- Automatically discovers and builds HomeSeer devices for other sensors supported by the Temp08.
- Logs all temperature readings to a OLEDB aware database.
- Currently supports Microsoft Access 2003 (database included), Microsoft SQL 2000 and Microsoft SQL 2005.
- Database queries for both Microsoft Access and Microsoft SQL server have been redesigned to automatically average the data based on the start/end date selected. For date ranges < 1 day, the chart data is averaged by minute. For date ranges < 7 days, the chart data is averaged by hour. For all other date ranges, the queries are averaged by day.
- Ability to open and close database connections while plug-in is running.
- Debuging output to troubleshoot database connection issues.
- Ability to specify custom connection strings.
- Ability to purge database records after a specified number of months.
- Ability to trigger HomeSeer2 events based on the device temperature.
- Charts available via ChartDirector version 4.
1-Wire Interfaces Supported:1-Wire Temperature Sensors Supported By HA7E/HA7Net:- 1 or more DS18S20 temperature sensors ($5 - $8 each)
- 1 or more DS18B20 temperature sensors ($5 - $8 each)
1-Wire Temperature Sensors Supported By Temp08:- 1 or more DS18S20 temperature sensors
- Other non-temperature sensors supported by the Temp08.
Quick Start Documentation:
http://www.automatedhomeonline.com/H...ultra1wire.htm
Ultrajones
February 28th, 2007, 07:38 PM
Change Log
Version 1.1.2615 - Released Feb 28, 2007- Fixed below 32 ° F temperature readings for DS18S20's and DS18B20's.
- Added support for Farenheight or Celcius reading when using the HA7E or HA7Net.
- Other coding enhancements.
Version 1.1.2636 - Released Mar 21, 2007- Removed Deg.F and Deg.C as temperature format options.
- Added "Date Format" on the options page.
- Added additional error logging output in routines used to connect to the HA7Net.
- Changed HA7Net discovery to support Windows Vista.
Version 1.1.2843 - Released Oct 14, 2007- Added HomeSeer2/html/images/hspi_ultra1wire images folder.
- Added code to ignoe invalid temperature readings from DS18S20 and DS18B20.
- Database connection and 1-Wire Checking HomeSeer device changes.
- Other internal code improvements.
Version 1.1.2917.26340 - Released Dec 27, 2007- Added ability to specify HomeSeer user roles (admin, guest, normal, local) that can access the web page.
- Fixed all outstanding issues with TEMP08.
Version 1.1.2994.29707 - Released March 16, 2008- Added plug-in help file link to HomeSeer help web page pointing at the included Ultra1Wire HSPI User's Guide PDF file.
Version 1.1.3073.34567 - Released June 2, 2008- Added new option to display degree image in place of the default "unknown.gif" image.
Version 1.1.3463.40799 - Released May 03, 2009- Modified database routines to support a variety of database providers (including ODBC, OleDB, SQLClient, MySQL, etc).
- Added watchdog HomeSeer event triggers [Database Connection Failure, Database Connection Restore].
Version 1.1.3471.25377 - Released July 03, 2009- Fixed database purge issue when using MySQL database.
- Added support for Microsoft SQL 2008.
- Date format now automatically determined based the short date specified in the System Control Panel.
Version 1.1.3595.25968 - Released Nov 04, 2009- Removed references to the deprecated Status properly of the HomeSeer DeviceClass.
February 28th, 2007, 07:39 PM
Screen Shots
Lastest Screen Shots ...
October 18th, 2008, 06:40 AM
Seer Plus
HA7E 1-Wire Interface With Vista 64bit
Ultrajones,
Does the HA7E 1-Wire Interface with Ultra1Wire software works on the 64bit version of Vista Home Premium?
renaatdb
October 18th, 2008, 08:59 AM
I have not tested it, but is should just work. There are no special drivers needed to access the HA7E. It uses 100% .Net code.
Ultrajones
May 1st, 2009, 11:58 PM
sensor types
what kind of one wire sensors can i use for outside temp/humidity? and what is the difference between the temp08 and the embedded products
Pro 100; HS 2.3; HST; napco 9600; mcs sprinklers; aprilaire hvac 8870s; RFXCOM; WGL800; ACRF; bitwise BC4; gc 100; x10; zwave; Ztroller; Sonos; Sling; HP Media Smart Server; Panasonic Phone system
May 2nd, 2009, 10:55 AM
At this time, the Ultra1Wire HSPI only supports humidity sensors connected to the TEMP08. I am not aware of a humidy sensor that can be used outdoors. This is what I have connected to my TEMP08:
The HA7Net also supports humidity sensors. I plan on re-writing the plug-in to add support for most sensors supported by the HA7Net. The HA7E will *only* support temperature sensors.
The TEMP08 connects to your PC via a serial connection. The HA7Net connects to you PC via your home network and mutiple PC's can access it at the same time.
Ultrajones
Plug-ins: UltraMon, UltraStatus, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug
May 2nd, 2009, 11:37 AM
what kind of wire is generally used and what are the connections?
June 18th, 2009, 04:40 PM
Trial rendered invalid after update to 2.3.0.19 (HS)
I'm a bit unhappy now. After upgrading my HomeSeer to Version 2.3.0.19 from 2.2.0.66 I had to recognize that Ultra1Wire plugIn is not working anymore, although there were still 11 days left from trial period.
The log shows the following initialization problem:
| 18.06.2009 22:26:48 | Info | Finished initializing plug-in Ultra1Wire | | 18.06.2009 22:26:48 | Error | (1) Unable to initialize interface Ultra1Wire :Either no license or trial has expired |
I wanted to check out the plug-in first if it is usable for me, as I had/have some troble still with it regarding the date format when accessing the database.
So I'm clueless once more.
Ideas ?
June 18th, 2009, 05:32 PM
Ideas ?
Please open a HomeSeer trouble ticket and request they reset your trial license. That will get you another 30 days. Please send me an email at ultrajones@hotmail.com so I can send you a version for testing that resolves the problem with a dot as a date separator.
Ultrajones
October 31st, 2009, 04:58 AM
Viewer
How can I test this plugin ?
I'm new to homeseer and I dont know how to do.
Thanks for helping me
Regards
Rene
October 31st, 2009, 06:43 PM
Regards
Rene
Do you own any 1-wire hardware like the TEMP08 or the HA7Net?
November 1st, 2009, 02:09 AM
Viewer
Yes I have one HA7E and 2 MS-TL and 2 MS-T
I just want to try the plugin but I dont know where I can find it to try ?
Best regards
Rene
November 1st, 2009, 02:21 AM
Try the Homeseer updater page.
Jon
January 1st, 2010, 08:48 PM
AAG Weatherstation
Ok, so I purchased the Temp08 unit with a handful of hobbyboards and all is well. I also ordered an AAG weatherstation (model WSI603A) and connected it to my 1-wire network only to find out it is based on the DS2760 and the Temp08 won't talk to it. When I purchased the AAG unit it included a USB-1Wire interface based on the DS2480 chip. It has two ports on the unit, though I would only need one to connect the weather station.
Will the ultra1Wire plug-in support both 1Wire interfaces? Simultaneously?
I would have the Temp08 with two 2408 I/O modules and two 2438 (Voltage and Barometer) connected. I would also have the AAG built DS2480 with the DS2760 based weather station attached.
Thoughts?
Hometroller - Win7 - HomeSeer Pro
TED 1001 (Switching to Current ENVI) - TrippLite 10KVA UPS
Z-Troller 1.15
DSC 632 w/PC5401
Trane XV95 - HoneyWell Zone Controller - 2x Trane Z-Wave Thermostat
DS9097U - Hobby Boards Weather Station, Humidity/Luminence, 2x 8Port I/O - mscTemperature
| Thread Tools |
| Display Modes |
Linear Mode
HTML code is On
