Onq Security plugin
I am using homeser2 and mainlobby as my front end to my system. I have an Onq Security panel working with the plugin and also there is a thermostat connected to the Onq security panel, all works great!!! I can control it all from homseer. I am having a problem writing the command in mainlobby to control the onq thermostat , I would like to be able to see the current temp reading of the thermostat and also adjust heat set point up or down and also see the value of the setpoint . Can this be done with this setup I have?
Can anyone help or steer me in the right direction Thanks
