| HomeSeer and Vista Discussions related to HomeSeer 2.2 and Windows Vista support. |
May 17th, 2007, 05:09 PM
HomeSeer Technologies
HA22 Z-Wave Interface Vista Drivers
I have been supplied with some Beta drivers for the HA22 for use with Vista. If you are having problems with the HA22 USB Z-Wave interface on Vista, please try these drivers and let me know if they help.
(new driver posted 5-29-07)
May 18th, 2007, 11:22 AM
The .inf file still has the old date/version info in it. Windows claims it isn't newer than the one that is already installed. The .sys file does appear to a different size, but without the updated .inf, it won't install.
May 29th, 2007, 02:06 PM
I received a new HA22 driver from Intermatic, its posted above.
June 2nd, 2007, 08:43 AM
Viewer
New Driver fixed the "Can't open port" problem for me
I was experiencing the "Can't open the port" problem everyone else was reporting with the HA22 on Vista. With the drivers from the post (plus a reboot), it started working.
J.
June 9th, 2007, 10:01 AM
Works for me, too...thanks so much for the follow-up!
May 23rd, 2009, 12:22 AM
Seer Plus
Did you get this working on Vista 32 or 64? Cant seem to get it working on 64. Not a Homeseer issue. Vista64 is telling me there is problems with the drivers.
thanks
Architect/Developer, WebHome:
Davis Family Central Command
HSTouch Screen Captures
HS 2.4.0.19, HSTouch on (2) 15" Touch Screen, ELK-M1G, x10 CM11/A, Zoned HVAC w/ (4) RCS X-10 Thermostats, X-10 Sprinkler Control, X-10 switches & outlets, Whole House Audio JRiver Media Center Mp3 Server / HS Plugin,
Phonetray for caller ID, Cheap RFID. Started moving from X-10 to Z-wave.
Just Moved System (HAL) to Quad Core, 4GB Ram, 8TB, 64bit Vista
May 23rd, 2009, 01:20 PM
We have not tested the driver on Vista 64. If it's not compatible, there may not be a solution since the HA22 is obsolete at this point.
| Thread Tools |
| Display Modes |
Linear Mode
