HomeSeer 2.2.0.66 is released. You can get the updaters below, or from the HomeSeer Updater. The help file has also been updated and can be installed from the HomeSeer updater.
The full setup installer has a new feature that removes your license from the PC you have installed HomeSeer on. Uninstalling the software will remove your license and all plugin licenses. This allows you to move the software to another PC without contacting HomeSeer. You prompted with this option and can cancel it if you are simply re-installing HomeSeer on the same system.
The full installer supports Vista.
The speaker client has not changed much, so you do not need to update remote speaker clients, unless you are experiencing the one issue listed below. The speaker client installer is below.
Update 2.2.0.66
HS2:
ftp://ftp.homeseer.com/pub/HomeSeerUpdate2_2_0_66.exe
HSPRO:
ftp://ftp.homeseer.com/pub/HomeSeerU...RO2_2_0_66.exe
HomeTroller:
ftp://ftp.homeseer.com/pub/HomeSeerUpdateHT2_2_0_66.exe
PRO100:
ftp://ftp.homeseer.com/pub/HomeSeerU...HW2_2_0_66.exe
Speaker Client:
ftp://ftp.homeseer.com/pub/SpeakerUpdate2_2_0_66.exe
Full HS2 2.2.0.66 Setup Installer:
ftp://ftp.homeseer.com/pub/setuphs2_2_0_66.exe
Full HSPRO 2.2.0.66 Setup Installer:
ftp://ftp.homeseer.com/pub/setuphspro2_2_0_66.exe
Changes from 2.2.0.11:
<!-- / message --><!-- edit note -->
Update 2.2.0.66
HS2:
HSPRO:
HomeTroller:
PRO100:
Speaker Client:
- Added support for saving and restoring z-wave node information that is stored in the PC interface. (Details to come in the help file in the final release.)
- In the listing of groups for the multi-event operations, "(Device Reference)" no longer appears. After editing an event from the
(Device Reference) group, when it returns the list of events is no longer blank. When you delete the last event in a group or the last
device in a location/location2, the listing tries to use the previous group or location/location2 before displaying the All Groups or All Locations list. - Added the ability to add/remove Z-Wave devices directly from Z-Wave status page (when HS is a primary controller)
- The device_state.txt file is cleared when a new configuration is loaded.
- Added support for the Z-Wave Node naming class (Usable with newer Z-Wave devices and handheld controllers that support this class.)
- Now displays the version of Z-Wave nodes when they are added
- Launching multiple identical scripts simultaneously should no longer cause "Item has already been added" errors.
- Fixed a bug with AddCondition not allowing TIME conditions (type 0)
- Added INI setting to display HSM100 temperatures in Celsius. Under Settings in Settings.ini, add HSM100FORMAT=F (or C) to set.
- Added battery device for Z-Wave motion sensors.
- Added support for the InTouch CA9000.
- Added support for dual Z-Wave interfaces being enabled at once in the PRO Edition or PRO hardware platforms.
- Added support for Ethernet/remote based Z-Wave interfaces.
- Added new replacement variables for TTS strings:$$LCIline) = Last Caller Info for (line)
$$LVM = Last VoiceMail Info
$$CINline) = Last CallerID Name for (line)
$$CI#line) = Last CallerID Number for (line) - Added support for new motion sensor that supports temperature and light sensors (HSM100)
- Fixed event conditions that are based on devices status being on or off for more than 24 hours
- Fixed plugins using ASPX pages that could display an error when first enabled
- Fixed Cancel All Events action
- Fixed memory leak in hs.GetURLIE
- Fixed PCI modem slow hangup issue
- Fixed phones not ringing after first ring with Way2Call hi-phone
- ExcludeNavLinks parameter now honored for hs.GetPageHeader
- Changed start.aspx page to more reliably return the proper WAN IP address
- Added support for the Leviton single scene controller RZCS1
- Fixed VR language XML file to now support UK VR on Vista
- Fixed plugin selections when similar plugin names are detected
- Removed mailboxes and addressbook XML files "are now saved" if they do not exist, which prevents warning message in the log.
- Network timeout shortened in hs.GetURL function to prevent excessive waiting
- Additional diagnostic information added to the "About" page
- Speaker Client's previously configured volume level is now restored upon startup.
- (For application providers) Added ReplaceVariables to the callback plug-in interface so that plug-ins could use the same ReplacementVariables function that HomeSeer uses to replace key tags in strings with values.
- (For application providers) Added a new control attribute modifier for ActionUI and TriggerUI that allows you to specify the column span of the cell.
- (For application providers) Marked CAPI classes as MarshalByRef for use by asp.net
- (For application providers) Added the following to the application interface so that scripts/plug-ins could get information about IR signals:Public Function GetIRDevices() As Collection
Public Function GetIRKeys() As Collection
Public Function GetIRZones() As Collection
