I had a DSC PC1832 panel with an IT-100 Data Interface Module installed yesterday. I've installed the plug-in, and connected the IT-100 to my PC with a DB9 serial cable.
The plug-in initializes without error and the "Arm/Disarm" command in HomeSeer reports "Partition Armed" and/or "Partition Disarmed".
However, there is no arming or disarming of the panel and there are no entries in the log. The status of all zones shows "Unknown". The "Bypass Zone" / "Unbypass Zone" buttons have no effect.
I've tried connecting with two different cables (both checked for TX/RX/SG straight through). The cables are no more that 40ft long (probably shorter) and the baud rate is set to 9600.
The LED on the IT-100 is blinking every 1/2 second (i.e. module is powered and sending/receiving data with the panel.)
I've run out of ideas. Anyone have any suggestions.
