Go Back   HomeSeer Message Board > HomeSeer > Home Automation Software > HomeSeer Phone
HomeSeer Phone This area is for discussions that are very specific to HomeSeer Phone including IVR script discussions and script postings.
Old December 14th, 2007, 12:29 PM
brsanders brsanders is offline
Default VoiceMail answering blocked by fax machine
Hope we can overcome this - would make life much simplier. PCI modem hears the incoming ring, but as my downstream fax machine starts "listening" for a fax tone, HSP see an offhook, then onhook condition. The voicemail never answers. If I disconnect the fax ( or any other device that listens - like spa control ), then voicemail picks up fine. Is there any way to tell HSP to ignore the passive "listening" devices ? I know the modem deals with voltage change to recognize on/off hook - can resistors or something be used to help mask these "listening" devices? Thanks in advance - BRS
12/14/2007 12:08:00 PM HSPhone Finished Resetting line: Line One12/14/2007 12:08:29 PM HSPhone Ring12/14/2007 12:08:29 PM HSPhone gRingStopTime = 800012/14/2007 12:08:29 PM HSPhone Line ringing (line Line One), count: 1 ForceAnswer: 0 Normrings: 312/14/2007 12:08:35 PM HSPhone Ring12/14/2007 12:08:35 PM HSPhone gRingStopTime = 800012/14/2007 12:08:35 PM HSPhone Line ringing (line Line One), count: 2 ForceAnswer: 0 Normrings: 312/14/2007 12:08:40 PM HSPhone Off Hook12/14/2007 12:08:40 PM Info Ignoring off hook due to incoming call12/14/2007 12:08:41 PM HSPhone On Hook12/14/2007 12:08:41 PM HSPhone Resetting line due to handset going on hook12/14/2007 12:08:41 PM HSPhone Resetting line: Line One12/14/2007 12:08:41 PM HSPhone Calling hangup for line: Line One12/14/2007 12:08:41 PM HSPhone Enter OpenLine, line: Line One12/14/2007 12:08:41 PM HSPhone Enter WaitForCall, modem: 112/14/2007 12:08:42 PM HSPhone Finished Resetting line: Line One12/14/2007 12:08:47 PM HSPhone Ring12/14/2007 12:08:47 PM HSPhone gRingStopTime = 800012/14/2007 12:08:47 PM HSPhone Line ringing (line Line One), count: 1 ForceAnswer: 0 Normrings: 312/14/2007 12:08:52 PM HSPhone Off Hook12/14/2007 12:08:52 PM Info Ignoring off hook due to incoming call12/14/2007 12:08:53 PM HSPhone On Hook12/14/2007 12:08:53 PM HSPhone Resetting line due to handset going on hook12/14/2007 12:08:53 PM HSPhone Resetting line: Line One
Old December 14th, 2007, 01:32 PM
JeffCharger's Avatar
JeffCharger JeffCharger is offline
Super Seer
Default
I don't know whether this will help in your situation or not, but my fax machine has an option of "do you have an answering machine on the same line?". When you specify "yes" I think it changes the # of rings required.
