Use VoipBuster to send an (free) SMS if an alarm condition occurs in the RFXCOM plug-in.
You need to have an account at www.voipbuster.com
Edit the script below with your parameters,
Remove the spaces from this string "< / B R >".
Create an Event that triggers on an alarm condition and execute this script.
Sub Main(Optional ByVal pParms As String = "") Dim strUserName As String = "enter between these quotes your VoipBuster user name" Dim strPassword As String = "enter between these quotes your VoipBuster password" Dim strPhoneNumber As String = "enter between these quotes the phone number that should receive the SMS" 'the phonenumber should be in international format for example "+31653123456" Dim strMessage As String Dim chrSecCode As Char Dim intCharPos As Integer chrSecCode = hs.GetINISetting("Startup", "SecDevHC", "", "hspi_RFXCOM.ini") If chrSecCode <> "" Then strMessage = hs.DeviceString(chrSecCode & "3") intCharPos = Instr(strMessage, "border=0>") If intCharPos <> 0 Then strMessage = Mid(strMessage, intCharPos + 9, Len(strMessage) - intCharPos - 15) strMessage = Left(Replace(strMessage, "< / B R >", " / "), 160) Else strMessage = Left(strMessage, 160) End If hs.launch("iexplore.exe", "https://myaccount.voipbuster.com/clx/sendsms.php?username=" & strUserName _ & "&password=" & strPassword & "&from=" & strUserName & "&to=" & strPhoneNumber & "&text=" & strMessage) Else hs.WriteLog("RFXCOM", "RFXCOM_alarm_sms.vb ERROR: No house code found for security devices") End If End Sub
