Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Stipus Plug-Ins > PLCBUS Connector
PLCBUS Connector Discussion area for Stipus' PLCBUS Connector Plug-In.
Old September 10th, 2008, 11:50 AM
connoleg connoleg is offline
Default Setup Issue?
As a toe in the water I have recently installed a PLCBus PC interface (PLCBUS-1141) and a lamp module (PLCBUS-2026U) with the PLCBus Connector.
After setting up and registering the lamp module I set the lamp to ON (100%) in HS but the lamp came on dimmed to about 25%. Using HS I ramped the dim level to 95% which woked. I then switched the lamp OFF but when I switched the lamp back on it goes to 25% again.
Any ideas?
Old September 11th, 2008, 04:37 AM
Default
I reset the lamp device and deleted scenes etc and its working OK now.
thanks
Gary
Old September 11th, 2008, 05:07 AM
stipus stipus is offline
Default
OK.
In the PlcBus Lamp configuration (PLCBUS plugin web configuration interface), you have several options to dim the lamp to the last dim level, or to a specific level ... etc.
Best regards,
stipus
stipus
Running HS 2.2.0.66 with CM11a - PLCBUS 1141 - RFXCOM RF interface - Digimax 210 & RFX Temp Sensor, ACRF Plugin - Touchpad
Instant Messaging Connector - Direct Input Connector - Bluetooth Connector - SIP Voice over IP Connector - Skype Connector - Script Connector - PLCBUS Connector
HTML code is On
Copyright 1998-2011 HomeSeer Technologies, LLC
