Here is a new version V2.48.2.2 of the Bluetooth Connector plugin.
Change log since V0.45.2.2:
- Uses an updated Bluetooth library (Bluetools V1.21.848)
- Added the missing BluetoothClient.exe file to the HS2 directory.
How to install:
- Copy hspi_bt_2-48-2-2.zip to the HomeSeer 2\updates2\zips directory
- Copy pending.txt to HomeSeer 2\updates2 (replace existing file)
- Restart HomeSeer
Features:
- The plugin is compatible with the Microsoft XP SP2 Bluetooth stack, the Vista 32-bit stack, and with the Widcomm stack (v1.4.2.10 or later). It is not compatible with IVT, BlueSoleil or Toshiba BT stacks.
- Bluetooth device presence detection. You can configure different device values and device strings for away/detected.
- Bluetooth device signal strength (with the Widcomm Bluetooth stack). You can configure different device values and strings according to signal strength.
- An optionnal Bluetooth Client can collect bluetooth presence and signal strength from remote computers, and communicate its findings to the main plugin.
- With several long range Bluetooth dongles, the plugin allows you to triangulate the position of your Bluetooth devices.
- Web configuration interface for all parameters.
How to install the Bluetooth Client on a remote computer
- Once the plugin is installed, you can find a SetupBluetoothClient.msi Windows installer file in your main HomeSeer computer HomeSeer 2 directory.
- You have to copy this file to a remote computer and run it.
- The speaker Client must be installed on the remote computer (but does not need to be running).
[EDIT] Attachements removed as a new version is available from the updater
How to install:
- Restart HomeSeer
Features:
