| Script & Plug-In Development Discuss scripting for HomeSeer and general VBScript assistance. Use this forum to post incomplete scripts, script snippets or code samples. |
November 6th, 2008, 05:27 PM
Exception from HRESULT: 0x80020006 (DISP_E_UNKNOWNNAME)
I have written a simple Jscript:
// JScript test
if (hs.ison ("A1"))
hs.execx10 ("A1","off",0)
else
hs.execx10 ("A1","on",0)
The good news: It works! But: every time it runs I get the message:
6-11-2008 22:11:58 - Info - Event Trigger "Test script ATS"
6-11-2008 22:11:58 - Info - Running script in background: test.js
6-11-2008 22:11:58 - Debug TI103 - SendX10: A1 Cmd: 2 Dim: 0 Data1/2: 0/0
6-11-2008 22:11:58 - Error - Running script, script run or compile error in file: test.js0: in line 0 More info: Onbekende naam. (Uitzondering van HRESULT: 0x80020006 (DISP_E_UNKNOWNNAME))
What's going wrong? Thanks for your help.
Herbus, The Netherlands
HS 2.2.066
ACT TI203, DooNetwork
November 6th, 2008, 05:58 PM
I think you need an 'End If' after the last line...
GearHouse Club Member
FoxConn D525 Atom 1.8Ghz / Win7 32 / 4G RAM /
HSPRO v2.5.0.78 / 2 Z-Trollers / 50 Z-Wave devices
WGL800 / RFXCOM / OS Sensors / X10 Motion Sensors / DS10a / Schlage Lock / Way2Call
November 8th, 2008, 06:02 AM
Thanks, I have tried your suggestion.
Unfortunately it doesn't work.
8-11-2008 11:48:50 - Error - Running script, script run or compile error in file: test.js5009:'endif' is niet gedefinieerd in line 11 More info: 'endif' is niet gedefinieerd
Sorry it's in Dutch. Translated it says: Endif isn't defined. Tried End if also. Here the message is:
8-11-2008 11:49:36 - Error - Running script, script run or compile error in file: test.js1004:';' wordt verwacht in line 11 More info: ';' wordt verwacht
Checked the microsoft msdn at http://msdn.microsoft.com/en-us/libr...hk(VS.85).aspx
Endif or end if isn't described here. Seems that if/else doesn't need an endif.
Any suggestions?
November 8th, 2008, 06:34 AM
If you want to write your HomeSeer scripts using the c syntax, I suggest you try the script connector plugin.
It supports both VB and c# scripts.
November 8th, 2008, 06:41 AM
Does it support Jscript?
Unfortunately I have to use Jscript. I'm preparing a script to communicate with the communication engine that's connected to my alarm panel.
November 8th, 2008, 06:44 AM
No sorry, it doesn't support J-Script. Only VB and c#
But usualy you can do everything that J-script does using c#. I'm not sure about your specific application though.
November 8th, 2008, 07:00 AM
Ok, thanks.
It should be possible to get a simple 4 lines Jscript work without errors!
Help is very welcome to solve this problem.
November 8th, 2008, 07:08 AM
The c syntax uses ; at the end of all statements.
Did you try:
// JScript test
if (hs.ison ("A1"))
hs.execx10 ("A1","off",0);
else
hs.execx10 ("A1","on",0);
November 8th, 2008, 07:11 AM
Also, I'm not sure if J# is case sensitive, and if it supports optional arguments.
I would write:
// JScript test
if (hs.IsOn ("A1"))
hs.ExecX10 ("A1","off",0,0,false);
else
hs.ExecX10 ("A1","on",0,0,false);
November 8th, 2008, 11:22 AM
I've tried both. A1 is turned on and off just like my script.
But.........same error message appears.
November 8th, 2008, 12:03 PM
I love challenges... I never tried j-scripts before, but the following works fine with HS2.2.0.135
testjs.js
function Main( param )
// JScript test
if (hs.IsOn ("A1"))
else
I got the idea to add the Main function by looking at your error code... DISP_E_UNKNOWNNAME is the COM error when a property or method is not found within an object. Also the fact that it was working fine... your code was executing as global code, and then HS tried to call Main() and it was not found.
November 9th, 2008, 08:04 AM
Your great! Thanks Stipus this solved the problem.
I'm very happy   and a little dissapointed that I didn't found it myself
| Thread Tools |
| Display Modes |
Linear Mode
HTML code is On
