Subscribe to this thread to receive notifications of new releases of HomeSeer HS2 products. We will update this thread whenever there is a new release.
HomeSeer HS2 Latest Release
HomeSeer HS2 Release 2.3.0.0
Posted November 13, 2008
We are happy to announce the release of HomeSeer 2 version 2.3.0.0.
The links to the update installers can be found in the release notes document accessible through your HomeSeer updater.
The full installer will be posted to the downloads page within the next 24 hours.
There are a couple of changes associated with a new HomeSeer link menu feature that are enabled by default in this release, so please take a few moments to read the release notes so that you are not caught by surprise by the other numerous changes in this release.
You can also read the release notes and access the update installers here - the first link in the release notes document will take you to the details of what is new and changed in this release:
HomeSeer HS2: HS2 Release Notices
HomeSeer HomeTroller: HS HomeTroller Release Notices
HomeSeer PRO: HomeSeer PRO Release Notices
HomeSeer PRO-100: HomeSeer PRO-100 Release NoticesRegards,
Rick Tinker (a.k.a. "Tink")
HomeSeer HS2 Beta Release 2.3.0.9
A beta release of HomeSeer HS2 has been posted to the Beta forum and is accessible at this link.Regards,
HomeSeer HS2 Release 2.3.0.16
Posted December 19, 2008
We are happy to announce the release of HomeSeer 2 version 2.3.0.16.
The full installer is posted at the downloads page.
If you have not applied the 2.3.0.0 update yet, there are a couple of changes associated with a new HomeSeer link menu feature that are enabled by default in this release, so please take a few moments to read the release notes for that release as well as this one, so that you are not caught by surprise by the other numerous changes in that release.
HomeSeer HS2 Release 2.3.0.19
Posted December 23, 2008
We are happy to announce the release of HomeSeer 2 version 2.3.0.19.
The full installer will be posted at the downloads page shortly.
HomeSeer HS2 Release 2.4.0.0
HomeSeer 2.4 is released, you can download from our download page at www.homeseer.com.
Here is some key information related to this release.
* If you are using Z-Wave devices, please make sure you do a rescan of all your devices after you update. HomeSeer requires more device information and a rescan will force a poll of your devices to get this information. If you have battery powered devices, wake them up and rescan them from the device properties. The rescan from the Z-Wave manage page will not rescan battery powered devices.
* If you are using Z-Wave, it is advised that you optimize your network using the optimize button on the Z-Wave manage page.
The Changes:- Added support for Schlage Z-Wave door locks (encryption and beaming)
- Major re-write of Z-Wave support so new Z-Wave hardware can be auto detected and supported
- Added support Z-Stick USB Z-Wave PC interface
- Added ability to color code log entries
- Many bug fixes and stability enhancements
- Z-Wave thermostats are now supported natively
- Added support for Windows 7
- Better support for replication with Cooper Z-Wave remotes
- Better support for Z-Wave scenes
- Added support for more Leviton Z-Wave scene controllers
- Better support for Firefox and Safari web browsers
- Phone support now supports wildcards on matching phone numbers
- Addes support for multiple Z-Wave primary controllers to support large Z-Wave networks
- Added more features to assist in installing Z-Wave systems such detailed node information, and better optimizing
- Added new Z-Health Z-Wave feature to automatically maintain a Z-Wave network
- Faster application start up
- New icons for device status
- Better support for Z-Wave thermostats
- Added support for Trane thermostats
- Better user interface for managing Z-Wave devices
HomeSeer HS2 Release 2.4.0.6
We are pleased to announce the release of HomeSeer HS2 version 2.4.0.6. You may use the updater to download an update installer for this version, or you can find the update installer downloadable from the downloads page of our website. (The downloads page may not be updated immediately.)
Changes in this release include:- Fixed an issue with VR on Hi-Phone and Windows 7
- Fixed a bug with adding a secure device resulting in a database warning.
- Fixed an issue with Z-Wave thermostat triggers not working right.
- Extended the field sizes on many of the event actions in response to user requests, so that they would display more information while editing.
HomeSeer HS2 Release 2.4.0.11
Greetings,
Our latest release of HomeSeer HS2, version 2.4.0.11 is now available. You may download the update installers using the updater, or you may download them from the downloads page of the website. (The downloads page may not immediately be updated.)
Please see the notices in the updater, or after running the updater, in the (HomeSeer)\html\updates2\notices folder of your HomeSeer system.
Here is what was changed or added in this release:
- 2.4.0.11 - If Rescan (Full) is used, it now forces the retrieval of the Z-Wave command classes from the node.
- Fixed an error in the calculation of sunset and sunrise times for timezones having offsets that were not whole hours - e.g. Newfoundland's offset from GMT is 3.5 hours.
- 2.4.0.10 - Several changes with the handling of commands sent to multiple Z-Wave devices at once, including scene commands, as it was possible previously for an error reaching a node to cancel the send in the middle of the operation.
- Added LED control and LoadSense enable/disable control for ZRR150 in device properties
- All Deprecated API warnings can be disabled from the "Disable obsolete API procedure warning messages" setting in setup.
- Fixed Z-Wave startup to always leave the Z-Troller at 40K mode
- 2.4.0.8 - Fixed issues with Multicast Z-Wave commands.
- 2.4.0.7 - Fixed an issue with values from Z-Wave sensors containing negative numbers not being handled correctly.
HomeSeer HS2/HSPRO/HomeTroller has been updated to release 2.5. The update is available from the HomeSeer updater as well as the downloads page at homeseer.com.
11/29/2010 2.5.0.1 has been released. This update is available from our download page and fixes the following:
1) Z-wave locks connected to remote Z-Wave interfaces did not operate properly.
2) On the HomeTroller, a license error was received when trying to register the software or a plug-in.
