You may have noticed that whenever Homeseer crashes or the Speaker client application is killed, their notification icon is left in the Windows Task-bar system tray (notification area) until a mouse is run over each
dead icon to remove them.
This small utility will attempt to remove these and any other dead icons at any time you run the supplied script. Normally you would add this to run via your startup.txt but you could also run it from a recurring event from time to time.
This has only been tested on my Hometroller, however it should work on most 32 bit Windows OS. There are also certain conditions regarding the task bar (i.e not set to auto-hide) so please read the instructions included with the download.
As aways, it is available from my site (click on the banner below).
